12v Continuous
Old Jul 13, 2013 | 11:44 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
12v Continuous
No Power from 12 v continuous (92 Camaro... orange wire) Radio Fuse good, ACC fuse good, 20A fuse next to battery good. any ideas?
Old Jul 14, 2013 | 12:31 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: 12v Continuous
find a wire with 12V with the key off and use that, should be able to find one on the fuse box.
Old Jul 14, 2013 | 01:51 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: 12v Continuous
Did you check the fuses on the drivers side by the center console? Where the headlight buzzer module is located
Old Jul 14, 2013 | 05:15 AM
Car: 92 Camaro RS
Engine: 305 TBI
Re: 12v Continuous
where is that exactly? If your referring to the fuses where your left knee is while in the driver set the answer is yes.
Old Jul 14, 2013 | 07:21 AM
Car: 92 Camaro RS
Engine: 305 TBI
Re: 12v Continuous
UPDATE: Problem Solved, I have the stock options for my stereo system so the Constant Hot "Orange" wire is suppose to be wired to the ACC fuse. BUT apparently the vehicle had the option for the Bose system and power antenna and was wire up as such. The constant hot was actually wired to the 20A ARC fuse which was blown.
Old Jul 14, 2013 | 08:13 AM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Re: 12v Continuous
Hi Blue wrath, noticed you're in Alexandria.. I'm in Culpeper. Hopefully a few of us can get together and cruise down to VB one weekend... you're welcome to join us.
Stone
Old Jul 14, 2013 | 01:31 PM
Car: 92 Camaro RS
Engine: 305 TBI
Re: 12v Continuous
Stone
Sorry I lived in NOVA for about 4 years and I just move back to NY a few months ago. Hit up Mr. Awesome from my friends list he lives in Ashburn pretty cool dude.
Old Aug 9, 2013 | 05:41 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Re: 12v Continuous
i had this problem also, there is a 20 amp fuse in the fuse box under the driver dash clossest to the fire wall.... pull that one.... or just pull every 20 amp fuse.. youl find it eventually lol
KCG
Jun 24, 2020 04:33 AM
Elephantismo
Feb 13, 2019 12:51 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
327IROC85
Sep 23, 2015 12:11 AM
Slush92RS
Sep 2, 2015 08:56 PM
