New Door Buildouts & Speakers
Old Aug 2, 2013 | 10:26 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Working on putting a new system in my IROC. Going from two to one mid in the door. Door speakers for now will be Clarion Pro SSS501 comps.
Old door buildout. Keeping the buildout but changing the speakers.
Removed insert
Cut new inserts from MDF and seal the wood
Few coats of Red Engine Enamel paint and three coats of clear coat
DONE - Hushmat Sound Deadener will be applied to entire back of the insert
Will run the speakers off the deck power for now.
Deck is a Pioneer Premier P880 with Humount insert.
Also picked up an Image Dynamics IDMAX 12" sub that will go in the rear hatch area next year.
Undecided on an amp but front contender is the Alpine PDX-V9
Old Aug 20, 2013 | 09:24 PM
Choldren's Avatar
Car: Z28 camaro T-tops
Engine: 2.8 v6
Re: New Door Buildouts & Speakers
looks good how did u mount it after you cut it because ive been wanting to put door speakers in my car as well
Old Aug 20, 2013 | 09:35 PM
Car: 89 IROC
I made two set of door inserts. One set (sealed but unpainted) is screwed to the door buildout and the second set will use the speaker screw to attach to the first buildout.
The fact that the second set (painted) also has deadener applied to the back helps with vibration.
I had to do it this was as the original speakers were 6.4" and the Clarion's are smaller.
Eventually I will put 6.5" speakers in so this only has to last a year or so.
Old Oct 13, 2013 | 10:22 AM
87350IROC's Avatar
Car: 87' IROC
Bill,
That is looking real good. I am working through my interior and now is time to do custom door panels. So I have some specific questions for you. I am ready to get my 6.5"s out of the dash.
Are the buildouts sealed? Do the speaker magnets poke through the buildouts and door panel?
How far do the buildouts come off the door panel?
How deep are your speakers?
Any concerns with knee space?
Thoughts on door speakers vs kick panels regarding both knee/foot space and sound quality?
Thanks,
John
Old Oct 13, 2013 | 07:16 PM
Car: 89 IROC
Originally Posted by 87350IROC
Bill,
Thanks,
John
Hi John,
Thanks for the kind words.
No they are not sealed but have Dynamat behind the speaker.
Yes, I had to cut parts of the door metal to get them to fit. They are very close to the PW motor but no interference issues.
Total is 2"
Speakers were just over 2.5". If the panel is flush with the front of the buildout, I have just over 3" of clearance
NONE
Personally, I'd go with door buildouts. Better sound and foot room. If you decide on kick panels, build them out flat rather than the Q-forms that have the speaker on an angle.
I'm going to run the tweets in the dash and see how I like the sound. If I'm not happy, I'll mount them in the A-pillar. off axis.
I picked up a set of Hertz MLK's (Baby Mille) and will install when I decide on an amp and ready to do a full stereo install.
Old Oct 13, 2013 | 07:47 PM
87350IROC's Avatar
Car: 87' IROC
Excellent, that was my plan.
Ok. Good to know, I figured the magnets would be right on top of the motor, but maybe there is some room to mount just away from the motor.
Total is 2"
Ok, that is not too bad. My thought at the moment is to use slim (1.75-2") speakers and avoid metal work, but still have good knee clearance. I feel like there is some clearance between the door panel and the metal behind, do you have an idea off hand?
NONE
That is really helpful. My car is in a zillion pieces right now, so visualizing this is hard.
I ok, exactly what I was thinking on all fronts.
I have mine in the a-pillar right now, off axis. Driver side pointed to the passenger seat. I'm not sure how I feel about them there. To many variables to tell for sure.
Nice I was thinking about a set of Hertz slims.
Old Oct 14, 2013 | 04:44 PM
Car: 89 IROC
If memory serves, there is just under 1.5" of space. If I put the red panel flush to the buildout, I have just over 3" until I hit the motor. Perfect for my MLK's.
I know Hawk92z-TDZ used a 3/4" spacer and Hertz space/slim speakers in his door with no issues (see link)
http://ccfbg.com/forum/viewtopic.php?f=41&t=7840
Old Oct 14, 2013 | 07:14 PM
87350IROC's Avatar
Car: 87' IROC
That is encouraging. I will start a new thread with my own plans. Don't want to clog this up any further.
Old Oct 15, 2013 | 01:52 AM
Car: 89 IROC
Don't forget to send me the link to your build thread.
Check out the Humount plates as well.
http://maptechenterprises.com/storef...1caf738ad4d49f
Old Oct 15, 2013 | 02:00 AM
87350IROC's Avatar
Car: 87' IROC
Will do. Already have a humount.
My original build is here.
https://www.thirdgen.org/forums/car-...-build-up.html
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
codeysabatini
Sep 20, 2015 11:36 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
