Should I amp or run off headunit?infinity reference
Old Sep 8, 2013 | 10:03 PM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
I've just purchased a set of infinity reference 4x6 and 6x9s for my bird, also have a alpine ics-x7hd headunit to power em all.
I have a 200 watt component amp laying about, would it be beneficial to amp these components or is the headunit more than capable to run them at there best.
Old Sep 9, 2013 | 07:04 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Should I amp or run off headunit?infinity reference
the hu peak power is 50 but likely 15-20 rms. if the amp is 200rms then 50w would be much better
Old Sep 9, 2013 | 08:07 AM
396lsx's Avatar
Engine: 350 tpi
Yea it's 200 rms, wasn't sure if 20-30 watts would make a noticeable difference.
Old Sep 9, 2013 | 11:03 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
thats at least double. which ones are they exactly so i can look up the specs? might be better to bridge the amp for the 6x9s and run the fronts off the HU, thats how the power specs usually work out with 4x6's
Old Sep 9, 2013 | 11:13 AM
396lsx's Avatar
Engine: 350 tpi
The 4x6's are 6432cf the 6x9's are 9632cf
Old Sep 9, 2013 | 12:56 PM
Rich92Z28Conv's Avatar
Car: 1992 Z28 Convertible
Engine: 363 TPI
When I had my 88 convertible, I tried the incremental approach to improving my sound system.
First, I tried replacing the head unit with the stock speakers. It was an Alpine head unit that said 40 or 50 watts per channel. No real difference here.
Then I replaced the speakers with Alpine speakers that were compatible with the head unit. A slight improvement but no punch.
All the while, the stereo guy was saying I needed an amp and a sub-woofer, but he was patient with me while I experimented.
My last iteration, which I liked very well, had the head unit drive the front speakers and the pre-amps for the rear speakers to the 200W amp in the trunk and I took half the amp to drive the rear speakers and the other half to drive the sub-woofer.
At that point, I had the sound I was looking for.
When I get to the point with my 92 convertible restoration when it's time for the sound system, I will probably do pretty much the same thing.
I also think that everybody has a different view of what sounds good, depending on the type of music you play.
I found that the sub-woofer added a layer of bass that I found very beneficial, so every car since then, has had a sub.
Good luck.
Old Sep 9, 2013 | 01:19 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
i think i would run the fronts off the hu and the amp i would bridge for the 6x9's since they can go to 100w. i think this will sound the best.
Old Sep 10, 2013 | 05:39 PM
396lsx's Avatar
Engine: 350 tpi
sounds like a plan to me
Old Sep 11, 2013 | 06:33 AM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Aren't infinity speakers 2 ohm? If that's so your going to need the amp. Contrary to what infinity says they don't work very well with a head unit. Make sure you don't put too low of an ohm load on the amp. I can think of a dozen ways to wire the speakers but that all depends on the amps ohm load capabilities and how many channels the amp has.
If I'm wrong about the speakers being 2ohm then just ignore my post. Good luck!
Old Sep 11, 2013 | 08:27 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
not sure if that means 2 or 4. i thought 4. but if they are 2 they need hooked to the amp and the amp specs need to be checked for compatibility.
"True Four Ohm Impedance technology: speaker's 2-ohm impedance combines with speaker wire impedance for a 4-ohm load"
Old Sep 11, 2013 | 10:08 AM
396lsx's Avatar
Engine: 350 tpi
"True Four Ohm Technology
The engineers are Infinity have developed a speaker that works for all applications. The True Four Ohm Technology used in these speakers make it perfect for running directly of a headunit or with an aftermarket headunit and amplifier. All of the speakers in the Infinity Reference line feature a 2 ohm voice coil. However, when you factor in the small OEM speaker wire of most vehicles and the heating in the voice coil during use, the impedance actually seen by the amplifier will increase. Infinity has adjusted the speaker to be safely connected to any headunit.
4" x 6" 2-way Reference Series Car Speakers
Power Handling:
Peak: 240 watts per pair / 120 watts each
RMS: 80 watts per pair / 40 watts each
Plus One+ Injection-molded, polypropylene woofer cone
Hi-roll rubber surround
1" UniPivot edge-driven, textile dome tweeter
2 Ohm impedance/li>
True Four Ohm Technology - speaker's 2 ohm impedance combines with OEM speaker wire impedance for a 4 ohm load
Top-mount depth: 1-15/16"
From what I understand they are a 2 ohm voice coil but when combined with the factory wiring they say the load equals 4... Well I'm not using factory wire, kicker spiral speaker wire is what I'm using. So I should amp all 4 I guess. May need a bigger amp. Any recommendations? I want it small enough to fit in the side in the spare tire thing.
Old Sep 11, 2013 | 10:48 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
what amp do you have now?
Old Sep 11, 2013 | 11:09 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
http://www.sonicelectronix.com/item_...TX-TD75.4.html
http://www.sonicelectronix.com/item_...t-OA400.4.html
http://www.sonicelectronix.com/item_...t-RM440.4.html
Old Sep 11, 2013 | 11:21 AM
396lsx's Avatar
Engine: 350 tpi
Honestly I'm not sure the brand. Ill have to look next time I'm at my shop since work has me busy with overtime right now.
All I know is its a 200 watt 4 channel.
I do have a db drive spa 120.4 4 channel amp but its big and I'm not sure where to put it. And it may be overkill
Old Sep 11, 2013 | 03:39 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Decent amps are cheap. Tweeters off the HU and amp the 6x9's.
Old Sep 11, 2013 | 04:51 PM
Car: 92 Camaro RS
Power Handling:
2 Ohm impedance/li>
It would be very easy to check infinity's claim but only after you had at least one speaker hooked up. Just use an ohm meter or multimeter and meter that speaker at the plug that goes into your head unit. That would measure the resistance/ohm load of the wire and speaker together at the head unit.
Old Sep 12, 2013 | 12:49 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
way over kill. the amps i posted are pretty small. not sure exactly what the size is of where you want it though
RazorN8
Jan 7, 2022 11:44 AM
SPEEDY Z28
Aug 17, 2015 01:46 PM
Irocohio
Aug 12, 2015 08:03 AM
ZsTransAm
Aug 11, 2015 07:30 PM
