here's a silly power wire question...
Old Sep 21, 2000 | 12:31 AM
Zant69's Avatar
Ok, I used to have two amps in the back, one for bass and one for mids and highs... but then I got a four channel rockford fosgate that requires 4 ga. power wire. The two wires that went to the old amps were both 8 ga. so for the time being I just hooked BOTH 8 ga. wires to the amp. two 8 ga.= one 4 ga. right? it has worked fine so far... and if it's safe to do I'd really rather not pull all that wire out and put new 4 ga. in... but, if it's unsafe I don't want that either... thanks for any info... and I told You it was a silly question... hehe thanks!
Old Sep 21, 2000 | 01:37 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
It should work ok. Make sure you have them properly fused. i.e. if the reqs are for 4ga and fused with a 60 amp fuse, then if you have 2 8ga wires, each wire must be fused with 30 amp fuses, NOT 60 amp fuses.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
[This message has been edited by Justins86bird (edited September 20, 2000).]
Old Sep 21, 2000 | 07:09 AM
GndPrx's Avatar
Actually, I do believe that 4 8awg make 1 4awg.
Just a technicality, but you should be fine
GndPrx
http://www.caraudioresources.net
EFNet #car-audio ; #caraudio
Old Sep 21, 2000 | 07:48 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
2 8 gauge makes 1 4 gauge.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 21, 2000 | 10:11 AM
GndPrx's Avatar
For some reason it just sticks in my head that it takes 4 8awg. But I give, I guess it's only 2.
GndPrx
Old Sep 22, 2000 | 01:02 AM
Zant69's Avatar
Yeah, I thought it would be ok... I forgot about the 2 30 amp fuses instead of the 60, though... I forgot to mention that both the 8 ga. wires are from the battery (of course) with the remote coming from the fuse box... but, Ya'll figured that out.. Thanks a bunch guys! Brant
BRoss99
Aug 10, 2025 05:08 PM
Bert87
Aug 23, 2015 03:50 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
