How does one change Front speakers?
Old Oct 1, 2000 | 09:40 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
The title pretty much says it, I have a 92 Rs and im about to change them. how do i get them out? do I have to take out the dash to get to them? if so any recommendation on an easy way to accoplish this. Also any recommendations on where to put a realativly small amp?
Chris
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat,
Old Oct 1, 2000 | 10:03 PM
92fireaudio's Avatar
Remove the screws from the dash, lift dash out. The speakers should be screwed in, unscrew them and you're set. If you have oversized magnets on the new speakers, you may have to manipulate them to get them to fit but I've put 4 different pair in my car and none had problems (Cerwin vega, Pioneer, Clarion and recently kicker).
As far as the amp goes, it depends how big it is.. i've seen some that actually fit into underneath the dash (cutting required) and I've seen some people put it underneath the passenger side of the car (above where your feet go, by the kickpanels). I've got both of my amps in the back because they are simply too big to put up front.. If the amp is for a sub or something, I would suggest putting it in the glove box in the back as long as you can get proper ventalation back there.
Hope that helped. Changing the front speakers can be akward at first but it's really a simple task..
Old Oct 2, 2000 | 07:59 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Don't forget to read the tech articles on this site. There is one that outlines all installation procedures.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 2, 2000 | 01:03 PM
myposcamaro's Avatar
yea what fireaudio said
in your 92 do you have a lockable trunk well lid? i have one in my 84 and i mounted my amp to the underside of that. its out of sight and theres sufficient air
Old Oct 2, 2000 | 07:48 PM
Car: 92' RS
Engine: LO3
Its not really lockable. It has the electric pull down motor.. Which can be opened by a switck or a key behind the license plate
160 stat,
Old Oct 2, 2000 | 09:51 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Not many of the Camaros had the trunk well lid that you are referring to. (This is the one that covers the lower part of the hatch area, if I understand you right.) In fact, I personally haven't see any newer than '87 I think. It's not hard to add though. I'm about to put one in mine that came from a Berlinetta, just for the sub amp, and to keep the sub out of sight. I was actually impressed with how the sub sounded being covered up with this panel!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Starting to look like the Kicker poster child!
Old Oct 3, 2000 | 10:00 PM
rd44bb's Avatar
Dont ever mount an AMP upsidedown! The heat sinks are made to push the hot air up, but heat rises so when it is turned around it compleatly defeats the purpose of any heat sinks!!!
Old Oct 4, 2000 | 12:02 AM
Car: 92' RS
Engine: LO3
Ah, glad you told me, i haven't mounted it yet, but i may have done it faceing downward, not upside down, but downward facing some.
hey im learning everyday.
160 stat,
Old Oct 4, 2000 | 01:01 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Originally posted by JP84Z430HP:
Not many of the Camaros had the trunk well lid that you are referring to. ... I was actually impressed with how the sub sounded being covered up with this panel!
I know what you mean. The plate makes it act as a bandpass (almost).
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
