which bass mechanik CD should I get?
Old Oct 1, 2000 | 11:51 PM
matthew's Avatar
i would like to get one because I don't think my system is hitting hard enough. there are like 5 out there. I am looking for one that would supply good bass, test my system and most importantly NOT WRECK ANYTHING. I have to 12" perfects and I do not want to blow them. I am also worried about my 6x9s. Is there any danger playing those songs? I was thinking about getting v 5.0. it has a mix of songs and test tones or should I get sonic overload. it is a two CD set. they both cost the same at CDNOW.
[This message has been edited by matthew (edited October 01, 2000).]
Old Oct 2, 2000 | 12:31 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
As long as your systems is set up right, there is no danger. If your setting up your system, you prolly wont be playing at max volume anyways, but if you decide to crank it (guilty here ), these are some things you want to watch out for:[*]xover settings-You dont want really low bass reaching your 6x9s or 4x6s. If you hear distortion, turn it down!![*]amp gain setting-You dont want any distortion at high volume. Likewise, you dont want to be clipping at high volumes. If you do, your asking for problems.[*]your voltage-Sit for too long, your battery will be dead.[*]your ears-Dont crank up the sine sweep and sit by a tweeter unless you want your ears ringing for a week
BTW, I have the Quad Maximus CD.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
[This message has been edited by Justins86bird (edited October 01, 2000).]
Old Oct 2, 2000 | 09:53 PM
matthew's Avatar
Justin, do you like that CD? does it have a good variety? Any other opinions?
Old Oct 2, 2000 | 10:05 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Those bass CD's can be bad news! I was demoing my car for a buddy last night with one, and my amp died in the process! It's only a couple weeks old, and they're gonna replace it (for the second time).
I think this time I'll have them install the amp, and check all the wiring, etc.... I'm sure it is all fine, but it can't hurt to be sure!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Starting to look like the Kicker poster child!
Old Oct 2, 2000 | 11:33 PM
Seems pretty good. Last half of the disc is stuff like sine sweeps, pink noise and test frequencies. Its a rather old disc now. The tracks on it is mostly just bass. If you want to test your mids and highs, get the Blues Brothers soundtrack. If you have really good speakers, the horns in the songs sound so killer
-Justin-
Old Oct 2, 2000 | 11:36 PM
I had a similar result one time. Had it cranked, and then poof!, no bass. Turns out what blew was just a 50 amp fuse.
-Justin-
[This message has been edited by Justins86bird (edited October 02, 2000).]
Old Oct 6, 2000 | 09:54 PM
AtomicWart's Avatar
Bass Mekanik v5.0. A buddy of mine actually worked on the truck on the cover of the cd. It has a couple great tracks to test your system plus test tones(tracks 20-99) e.g. track 20 = 20hz.
wanext
Oct 6, 2015 12:18 AM
Makaveli
Car Audio
Feb 25, 2001 03:46 PM
Ed Maher
Car Audio
Jan 31, 2001 08:31 PM
Sweet_85_Bird
Car Audio
Jan 18, 2001 12:57 AM
86V6
Car Audio
Jan 6, 2001 06:07 PM
