Amp Help
Old Jun 23, 2014 | 12:07 AM
Zeifer's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
Amp Help
So I have two amplifiers, both of which worked until today. One 250W Craig Powerplay 500 from the 90's, and one Memphis Audio 600W.
The Craig makes the sub pulse and you hear radio interference in the sub.
The Memphis outputs no sound, and during troubleshooting, now it just blows both 30A fuses.
I've tried multiple decks and RCA cables and grounding points.
Old Jul 3, 2014 | 09:30 PM
lvlik9's Avatar
Re: Amp Help
still need help
Old Jul 14, 2014 | 11:41 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Amp Help
I think I would take the Memphis out and bring it up close to your battery. Replace the fuses, connect the Power and ground to their respective terminals and see if the fuses hold. If so, I'd then put another hot wire on the remote turn on. If any of these things blows the fuses, you know you have an internal problem. If not, I'd probably take it back to where it's mounted and introduce each wire you have been using one at a time and see what makes them blow. It's really odd they both acted up at the same time.
Old Jul 15, 2014 | 10:01 PM
Zeifer's Avatar
Engine: 408 LSx
Memphis hooked straight to the battery blows fuses, it's shot. Nothing is blown though.
Old Jul 16, 2014 | 01:06 AM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Amp Help
Yep, something inside has gone haywire. Do you plan on looking inside of it?
The Craig sure sounds like a ground problem. Maybe try substituting a ground straight from the battery just to test?
Old Jul 22, 2014 | 03:45 PM
Zeifer's Avatar
Engine: 408 LSx
Pulled them apart, Craig fried, Memphis was clean but something still busted. Gotta buy a new one now.
Old Jul 22, 2014 | 09:09 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Amp Help
Any pictures inside the Craig?
Old Jul 22, 2014 | 11:18 PM
Zeifer's Avatar
Engine: 408 LSx
Unfortunately no, I pulled it out a few days ago and scrapped it. It didn't have enough power anyway. I got my 60 bucks out of it. 2 years of use in 2 cars.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
