Help! Mystery/disconnected wires in sound system
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
I bought this 92 Formula last winter, and with all the work I've done I'm just now getting around to the sound system. The radio is a decent Kenwood (KDC-BT645U), but the system the PO had is partially removed. The radio works, but no sound comes out of the speakers because I don't think they are connected to this radio. I have the wiring harness pictured below in my rear hatch. I'm guessing the four copper wires are speaker wires, and the blue wires are already at the back of the radio. The larger copper wire looks like the one that is connected to the battery, and that runs through the firewall. The black and red I'm not sure about (the little blue one is ground?) Is this amp power? If so, then what is the copper wire from the battery for? I don't know much about car audio, but it looks like the hardest part is done. Do I just plug and play here? If so, what plugs into what? I'd like to get a modest system in there, 250 watts is fine. But if the box is in the hatch, will it project toward the front enough to make a decent sound? Any help would be appreciated!
Engine: 5.7L T.P.I.
Re: Help! Mystery/disconnected wires in sound system
Here's the under hood wire. Looks like it needs a fuse?
Car: 91 Z28 Coupe
Yeah fuse is missing. Blue wire maybe a remote "on" for amp. When Ign is in on position, it supplies power to amp. Really cant tell from just the pics.
Red is constant hot to amp, blue is signal to turn amp on, black is ground, RCA jacks are input to amp from head unit. You're gonna have to figure where the speaker wires go.
Disclaimer: This is the best guess I can give without being there. But colors seem to fit this. red and black, obvious, blue is typical power antenna signal also used for amp, RCAs, obvious. Red wire goes to the underhood inline fuse.
Engine: 5.7L T.P.I.
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Ok, best I can tell, this was a 6 channel setup with a single 6 channel amp. The RCA cable with the 4 ends would be your mid range speakers front and rear, while the other one with 2 would be the subwoofer. It's up to you if you want to go that route or just get a 4 channel amp.
I can tell you that 250watts to a pair of subwoofers in the trunk will be more than loud enough if you only want a modest system, HOWEVER, you wont find a 5 channel or 6 channel amp that only puts out 250watts.
I think something like this would work for you...
http://www.sonicelectronix.com/item_...-OA1100.5.html
Match that up to a sub box that can handle 350watts @ 4 ohms or 500 watts @ 2 ohms and you will be golden. It will be MORE than enough to hear from the rear of the car.
I have a 250watt amp running 2 12" subs and I can shake the car with it. The reason is the shape of the rear hatch. It creates a folded horn effect. A small space that opens to a larger space and amplifies the sound created in the smaller space. Similar to a megaphone.
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Oh and as far as connecting it, Im assuming the 4 "copper" wires you have are already connected to the speakers in the factory locations, front and rear. Use a multimeter and set it to ohms and connect one wire to the red lead, then touch the black to each of the other wires until you find a combo that gives you a value other than 0. That means those 2 wires go to a single speaker. You can have a friend connect a 9v battery to each wire and listen for a small "pop" sound. All it does is push the speaker out or in once. This will help you try to find which wire goes to which speaker. Keep popping the speaker until you figure out where it is. The sub box wiring is obviously missing, but a few lengths of speaker wire and your good there.
Engine: 5.7L T.P.I.
Engine: 5.7L T.P.I.
db057
Aug 11, 2015 10:11 PM
