speaker and box volume...
Old Oct 25, 2000 | 04:39 AM
82taGODD's Avatar
say i have a speaker, and the recomendation is for a sealed enclosure with .88 cubic feet. if i were to put it into a sealed enclosure with .85 cubic feet would that be a terrible nono or would the .03 cubic feet be not to big a deal??? thanks in advance.
Old Oct 25, 2000 | 08:18 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Sealed boxes are more forgiving to differences in volume. A +/- 10% variation is usually hardly noticable. Making the box slightly smaller isn't going to make much difference. Just pack it with about 3/4 to 1lb of polyfill.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 26, 2000 | 11:22 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Gee, .88? Sounds like Solobaric 12 spec! I'm about to build a box for one, and it is going to be a bit over (small bit). Also, make sure that you are using internal volume of the box. I used to get this messed up and use the outside volume. In a small box, that can make a big difference!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Starting to look like the Kicker poster child!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
