anyone put anything besides 4x6's in front?
Old Oct 3, 2000 | 10:02 AM
steven's Avatar
i have 2 inch tweeters, what else will fit good, i'm not real fond of 4x6's.
191(3.1)V6 1992 Pontiac Firebird,K&N drop in filter, bosch patinum spark plugs, Sony 6x9 xplods, 2" tweeters, a 12" and 8" sub(a friend gave them to me, not sure what brand), check it out at www.geocities.com/my_92firebird
Old Oct 3, 2000 | 10:26 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can fit 4" separates, and some have even stuffed 5 1/4" separates up there. There is always the kick panel option too.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 3, 2000 | 11:21 AM
PRICEZ28's Avatar
i have sony 3 1/2 up front.
i traced the factory speaker onto
5/16 inch plexi-glass and then cut it out and cut the hole for the 3 1/2 speakers.
i like it.
Old Oct 3, 2000 | 01:16 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Steven,
I originally stuffed Eclipse 6.5s in the dash, and they sounded great! I ended up taking them out because the angled tweeter on the Eclipse's very slightly bowed up one of my grilles. Didn't cause any damage, and it went right back down when I changed it.
I liked the 6.5s a lot. The key is to find a pair WITHOUT an angled tweeter, and to find some that have a mounting depth of 1 3/4 inches or less, which is hard to find (hence why I had the Eclipses). You will need to hack up the speaker brackets though, which you may not want to do. I replaced mine with a junkyard pair though for only $5 when I put my 4x6s back in.
Jason E
'89 Camaro RS 2.8
Grey/AT/T-tops/all power
Hypertech chip/2 K&N filters/Accel cap/rotor/8.8 wires
Eclipse CD and 100x4 amp/Boston 746 4x6 plates and RX 6x9 3 ways/ALL Monster's goodies
Alpine Alarm w/ Keyless entry
IROC tailights/t-windows
Old Oct 3, 2000 | 09:47 PM
rd44bb's Avatar
does anyone make a 4x6 to 4 converson plate?
88 Olds toronado trofeo 3.8. Black with gray leather
It's a 305 with the last two cylinders cut off...
hehe
165 H.P.
215 lb/ft Torque
Pioneer DEH-46DH
Pioneer TS-A6969
Stock "Dimensional Sound" Seperates up front.
My Trofeo Site
realdeal44 on AIM!
Old Oct 3, 2000 | 10:02 PM
350iroc-z's Avatar
I made my own that would use the stock plate.
Pictures are on my website under car audio and also under misc pics / car audio.
It wasnt hard to do at all. Hope that helps
www.350iroc-z.com
Old Oct 20, 2000 | 02:39 PM
nestz28's Avatar
I put 4" round kenwoods in mine. I bolted them up on one side and made brackets out of sheet metal to anchor down the other side. They sound really good, better than 4*6s would in my opinion.
Old Oct 22, 2000 | 01:19 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I have a pair of Kicker Resolution 4's in there, along with the r25 tweeter. Sounds great.
All I did was cut a piece of sheetmetal out to fill the 4x6 hole in the bracket, welded it in place, then I drilled out the holes for the speakers.
I suppose you could use a thin piece of wood in place of the metal.
Old Nov 2, 2000 | 01:54 PM
87 Firebird's Avatar
I have a set of Pyramid 3 inchers (I think) in front, rated at 100 watts. They suck!!! The guy who put those in obviously had no clue what he was doing, by choosing this lousy of speaker. Also, he mounted the speakers on some ugly-*** yellow plastic, which vibrates like mad. I'm going looking for 4x6 plates of some sort tomorrow...
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
