Delco Bose Low Volume and distortion
Old Mar 4, 2015 | 09:06 AM
GASPEDDLER's Avatar
Hey guys do you know if there is a separate fuse for the amp or amps in my Delco Bose factory sound system? The radio starts up and there is some sound going to all speakers but it's at a low and very distorted level. I've adjusted the fader adjustment and still low and distorted. This occurs with am, fm or cassette adapter plugged into my iPhone. I have an 89 Iroc with the factory speakers in the luggage area locking cover. The car is new to me and the seller says it's worked fine over the years. I searched the forum but found mostly questions about aftermarket Amps and subs. Thanks in advance
Old Mar 4, 2015 | 03:08 PM
*84TA's Avatar
Car: 84 Trans Am
Re: Delco Bose Low Volume and distortion
Bad caps in the built in amps in the speakers. These can be repaired.
Old Mar 6, 2015 | 09:19 AM
GASPEDDLER's Avatar
PM sent
Old Mar 7, 2015 | 08:13 AM
GASPEDDLER's Avatar
Originally Posted by GASPEDDLER
PM sent
Pm sent
Old Oct 17, 2018 | 10:09 AM
MikeM2's Avatar
I see this is an old post but I have a very similar situation with my IROC Bose system. Anyone ever figure this out?
Old Oct 22, 2018 | 12:02 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Yup,.....
Old Oct 22, 2018 | 01:45 AM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
These guys will repair them at about 50 bucks each. You have one amp in each speaker. You have to take yours apart and send them your amps. They will repair and send it back. Only issue is I had is one capacitor came a little lose when I got mine back. I just hit it with a some solder and it took care of it. Could of sent it back on their dime I'm sure but didn't bother.
http://bosecentral.com/index.html
Old Oct 25, 2018 | 02:52 AM
John in RI's Avatar
I've got nothing but good things to say about BOSECENTRAL in FL. I've had them repair a few AMPS for me in the past,... even sent one back and it was repaired and returned to me in proper working condition.
Old Oct 25, 2018 | 06:42 AM
MikeM2's Avatar
Thanks. I’ll give them a call.
xxx3man`
Oct 2, 2015 10:39 AM
327IROC85
Sep 23, 2015 12:11 AM
BLK87Z
Sep 18, 2015 11:29 PM
snowflake
Sep 16, 2015 09:24 PM
scottmoyer
Sep 7, 2015 07:06 PM
