Oil pump swap
Old Sep 22, 2015 | 10:32 AM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Oil pump swap
How hard is it to change the oil pump with the motor still in the car? Also what's a good replacement stock or the high volume?
Old Sep 23, 2015 | 01:48 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Oil pump swap
Do you have 0 or very low Pressure?? bad OPSU? - ground, wire, or even the gauge, a stock pump is more then enough producing 45 - 60 lbs. If you do have very low pressure. You would also need to examine all the bearings.
Old Sep 23, 2015 | 01:51 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: Oil pump swap
No low oil pressure gauge is mechanical. I'm trying to track down a noise that my motor is producing and this is the last piece of the puzzle before I pull the motor and have to check the bearings. I don't want to pull the motor and check the bearings
Old Sep 23, 2015 | 01:57 PM
88gta3508's Avatar
Engine: 231 / 383
Re: Oil pump swap
pull the DIZZY. Make or get a oil pump prime rod. Spin this high speed on a drill. If you believe the noise is from the pump? you will need another ear to listen close to the oil pan.
Old Sep 23, 2015 | 02:04 PM
88gta3508's Avatar
Engine: 231 / 383
Re: Oil pump swap
Remove your serp belt fire up the car. just For a few moments.. Same noise?
Old Sep 23, 2015 | 03:10 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: Oil pump swap
Yes. I have another thread going about this problem. Mystery engine noise. Check that and it will tell you everything I've tried.
Old Sep 24, 2015 | 09:02 AM
88gta3508's Avatar
Engine: 231 / 383
Re: Oil pump swap
I would try my 1st suggestion. Pull the Dizz. Spin the pump with a drill using a prime attachment.
Old Sep 24, 2015 | 01:38 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Oil pump swap
This.
Old Sep 24, 2015 | 04:42 PM
88gta3508's Avatar
Engine: 231 / 383
Re: Oil pump swap
yes, this - will tell you if it is the pump going bad. You have eliminated all other possibilities. leaving you with the pump, Main/ Rod bearings. Or the timing chain???
Old Sep 24, 2015 | 06:12 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: Oil pump swap
I have tried spinning the pump with a drill but there was no sound. But that doesn't mean anything because the sound starts once the motor is somewhat warm as in 100-150. So spinning it up when it's cold didn't help. I suppose I could spin it after running it and it's warm
Old Oct 1, 2015 | 09:43 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: Oil pump swap
Ok you can not change the oil pump with the motor still in the car
Old Oct 2, 2015 | 10:39 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Oil pump swap
You can sort of change the pump with the motor in the car. You will end up wishing you had just pulled the motor. The trouble is getting the pan off. There is not enough clearance between the cross member and the trans tunnel to allow for raising the motor enough to clear the pan. If you pull the trans, disconnect wiring and hoses as needed, pull the radiator you can get the clearance you need. By this point, you may as well yank the motor.
One thing I have not tried is dropping the K member. This would mean disconnecting the steering and suspension as needed. I've seen others do it. I've seen the motor taken down with the K frame, like we do on late model cars. If you wanted to just lower the K frame and keep the engine up for clearance, you would need to support the motor from the top with a crane or hoist. It seems like it wouldn't be much time savings on these cars over pulling the motor out the top.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
