6X9s in the rear not putting out much sound?
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I noticed my in dash fronts are driving all the sound while the 6x9s in the rear pale in comparison big time. Not sure if my deck can't handle the speakers I put in the rear. They are kicker brand and have massive magnets (i'm no audio enthusiast or expert).
Factory speaker wire has all been replaced. When you crank the radio the factory replacement style pioneers produce all the bass and start cracking a bit. While the rear just makes mediocre output.
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Re: 6X9s in the rear not putting out much sound?
Try adjusting the fader on your radio, the fader changes where the sound is coming from, mess around with it and you will fix your problem
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I've found that, in my 88 as well as my Sunfire, I have to crank the fader towards the rear to get balanced output. In the 88, on the Eclipse, I have to set it to R03 (out of I think 8) and the 01 is set to the same (out of 4 on the JVC).
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Adjust fader... the "stock" amp in any deck can only do so much...
Large magnets usually require more power to be louder...
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Pioneer 1.5 din deck. Played with the fade and it helped but the output Bass wise isn't great and doesn't seem to go all that loud the sound gradually gets better as you fade it back to the fronts. I had this same setup in a vette which seem to have sounded much better for some reason. Maybe the rears are a bit too much, Ive had stock delco 6x9s that putout more bass and loud then these.
Car: 91 Z28 Coupe
If you are runnig an aftermarket head unit, just go the extra mile and add an amp with pre-amp inputs. That way you can just use you existing wires and not have to deal with RC inputs. You should also be able to control the output to your speakers from the amp.(depending on the amp)
Car: 89 IROC Convertible
Engine: 305HO
The rears could be out of phase also. Fade to rear left then to rear right, if it sounds more bassie out of one side or the other instead of the together they could be out of phase.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Between all the replies I managed to get it sounding pretty good.
Thanks for all the help.
Car: 1992 Camaro Z28
Engine: 5.7l TPI
I know you stated they are working better now but I just wanted to add that either your 50x4 deck is simply not giving your high end speaker enough power, or you might be expecting too much from a 6x9. While heavier in bass than other size speakers, they are not designed for that purpose. If you still find your bass not meeting your expectation you may consider either subs in the rear or a high quality component system for your fronts. Either way you will need to look for an aftermarket amp to do either of the approaches I mention.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I have 2 way 6x9 Pioneers in the rear with 3 way 6 1/2in pioneers front with a Kenwood deck and they are not made to produce a decent sounding deep base.
That does not stop them from sounding great.
I have always liked the Pioneers.
I left my dash alone and installed the 6 1/2in in the doors.
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
What are the rears rated for for OHMs? Not all factory radios can handle driving all speakers, esp. 2/4 ohm ones and sound will barely come out. I bought rear 2-way Infinitys for my car many years ago and had to wait until I replaced the head unit with an aftermarket Kenwood to get decent SPL from them.
What she's describing sound exactly like low OHM speakers being connected to amps that require 6+ ohms.
Also, speaker sensitivity could play a much smaller role with sound levels if the new ones have lower sensitivity than the front speakers. But, I'm willing to bet it's an ohm issue.
1992 Trans Am
May 10, 2023 07:19 PM
