lights dimming when bass hits
Old Dec 22, 2001 | 07:14 PM
redberlinetta86's Avatar
My headlights and dashlights dim @ night when the bass hits...not even playing it that loud...only running a 200watt RockfordFosgate amp bridged to two 10's...4 speakers running off clarion 50x4watt deck...8g power wire, newer battery, newer alternator...any ideas? should I upgrade my alternator?
Old Dec 22, 2001 | 07:29 PM
nagga's Avatar
get a .5 farad capacitor, that should solve your problem
Old Dec 22, 2001 | 10:41 PM
MotoGod's Avatar
Either install a stiffening capacitor....or upgrade your alternator to a higher output model. Caps are pretty cheap. In general...run 1 farad for every 1000 watts of power your pushing with your amps.
Old Dec 23, 2001 | 11:27 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Keep in mind that caps are not fixes to systems with low voltage readings, they stabilize the power to prevent dimming. If your volts are around 12 you need to install a HO alternator.
-Matt
Old Dec 23, 2001 | 03:33 PM
What kinds of HO alternators are there? Do you know of any that use the factory brackets? Any suggestions would be appreciated.
Old Dec 23, 2001 | 03:34 PM
Oh yeah: 2.8L V6, NO a/c
Old Dec 23, 2001 | 08:26 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
well, what year is your car? i bought a HO (100-140 amp) alternator for my 84 v6 and cant use it on my serpentine 89. lemme know if this is the kind you're lookin for. oh, and i believe summit still has HO alternators that bolt right in.
Old Dec 24, 2001 | 12:03 AM
MotoGod's Avatar
Most of the aftermarket HO Alternators should bolt right up....or you can take your stock one and get it rewound for higher output. Probably not much cheaper though!
Old Dec 24, 2001 | 12:26 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
There's a kit that is from JCWhitney.com that you can rebuild your alt with. It really made to better charge your batt. during cold weather, but it puts out 140 amps @ idle.
Someone in the Electronics Board told me to get it, and it was one of the guys that knows their ****.
I didn't get it, but that's cause my old alt was just shot. I didn't have the time to wait for the order to come.
AJ
Old Dec 24, 2001 | 12:46 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Be careful when buying a HO alt. There are many ways diff manufacturers rate them to sound good. Things like Hot and Cold ratings will affect the advertised output greatly.
Orr89RocZ
Feb 13, 2016 10:04 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
db057
Sep 4, 2015 07:57 AM
Glowsock
Aug 31, 2015 09:01 PM
Omega
Aug 10, 2015 12:46 PM
