Sub and amp combo?
Old Dec 25, 2000 | 12:55 PM
steven's Avatar
Sub and amp combo?
I need three subs, for under $350 each and an amp for under $500 what should i get that will hit realy really hard, thanks. later
191(3.1)V6 1992 Pontiac Firebird,K&N drop in filter, bosch patinum spark plugs, Pioneer reciver, kenwood 4x6's, sony xplod 6x9's, two kenwood tornado 12's with a 300 watt jenson running them, check it out at www.geocities.com/my_92firebird
Old Dec 25, 2000 | 01:49 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
How many channels do you want on that amp? Will it be driving all the speakers or just the subs? If you want 3 subs, get the JL W6s. The bigger they are, the more they will cost but a 10" shouldnt cost more then $250 each.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
[This message has been edited by Justins86bird (edited December 25, 2000).]
Old Dec 25, 2000 | 05:20 PM
steven's Avatar
sorry i want three 12's and an amp that will power maybe the other speakers also if possible.
Old Dec 26, 2000 | 12:09 AM
9177's Avatar
most good 5+ channel amps are pretty expensive you might try one less sub and an amp for the sub and an amp for the full range speakers. how much room can you sacrifice in your car. if you get good speakers and put them in to small of a box you just waste alot of time and money.
Old Dec 26, 2000 | 08:54 AM
steven's Avatar
i have a box made for three 12's that takes up the whole cargo hole area.
Old Dec 28, 2000 | 01:59 AM
You could do it with a 4 channel amp. I did for a while. The front and rear speakers were run off the 1st 2 channels at 2 ohms, the rear was bridged at 1.5 ohms (2 10W6s). Get JL 12W6s.
-Justin-
Old Dec 28, 2000 | 08:54 AM
Polecat's Avatar
steven,
I have an Kicker XS100 amp that will go down to a 1 ohm load. So it will put out over 1100 watts, and will power 3 12's easy. Selling it for $325.4 months old.
Kicker amps will power 3 8ohm woofers at a 2.66 ohm load, and will be effeciant and sound awesome.
Let me know.
Old Dec 28, 2000 | 01:52 PM
CamaroZ_85's Avatar
if you have a box made already then you need to find subs that will work in them...so the first factor in your decision should be the necessary volume
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
