Hey experts please answer this!!!
Old Feb 7, 2001 | 10:36 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
i plan on getting two JL Audio 12's and an MTX 1000d or at least the 500d. What type would i need to wire in parallel to get a 2ohm load? Thanx in advance for your help. Oh contact me i found a guy selling the MTX 12in 6000's for 90 bucks a pop (new).
Faster than a bullet, these are F-body's don't even pull it.
Old Feb 7, 2001 | 10:38 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you want a single 2 ohm load, you need each speaker to total a 4 ohm load. That can be accomplished by using JL subs that have dual 2 ohm coils. You series-wire the two coils, giving each sub a 4 ohm load. You then parallel-wire the two subs for a total of a 2 ohm load.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Feb 7, 2001 | 10:48 PM
Car: 86 Z28
Axle/Gears: TBD
got a diagram or know where i can get one??
Old Feb 7, 2001 | 11:24 PM
KlayBuRn's Avatar
Dude, its easy, just take the 2 positives off the speakers, and hook them up to the mono positive, then take the 2 negatives off the speakers and hook it up to the mono negative...make sure both speakers are 4 ohms... =)
Old Feb 7, 2001 | 11:43 PM
Jim85IROC's Avatar
The IROC Homepage
Old Feb 8, 2001 | 12:11 PM
daniel dekay's Avatar
nothing beats a picture
Old Feb 8, 2001 | 12:13 PM
if im not mistaken, dont JL audio subs only come in 2 ohm or 6 ohm loads? if that is the case, u will need like 3 subs to get the 2 ohm load. i was gonna go with the JL's 2 yrs ago, until i realized that i neeeded 3 to go with my amp (ppi 2150).
just a thought
daniel
Old Feb 8, 2001 | 12:37 PM
Jim85IROC's Avatar
W3s are available in dual 2 ohm, dual 4 ohm or dual 6 ohm configs. W6s are available in dual 6 ohm only.
The IROC Homepage
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
IROCtometal
Sep 2, 2015 02:01 PM
