Will putting these in parallel hurt something?
Old Feb 16, 2001 | 06:38 AM
Frank88's Avatar
My '88 GTA has factory subwoofers, rear speakers and front speakers. The previous owner had installed his own system with an amp (which he removed) and left the speaker wiring in a real mess. He had tied the subs into the rear speakers (just pig-tailed the speaker leads together) and led this to his amp. I'm installing a radio/CD player (Alpine)just to have some music, but I can't find the stock speaker leads where he cut them. If I duplicate what he did, can I hurt something i.e. subs and speakers in parallel?
thanks!
Old Feb 16, 2001 | 10:46 AM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
yeah, assuming the subs are 4 ohms each and the same deal for the speakers... running them in parallel gives you a 2 ohm load, and no head unit can handle that, not even your alpine. i'd say take a 1/2 a day and run new wires, its better than having to send out your head unit.
Old Feb 16, 2001 | 10:48 AM
Car: '89 TA
Engine: LB9
Transmission: M5
whoops, forgot one thing... if you're talking about hooking up the FACTORY sub and speakers, I don't know what kind of load they present. sorry if this only 1/2 answers your Q then
Old Feb 16, 2001 | 03:12 PM
Frank88's Avatar
Thanks - I do mean the factory subs. Does anyone know what load they offer? Can I just measure with a VOM and figure out what to do from there?
Old Feb 17, 2001 | 04:37 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I always use my DVOM to tell me what Ohm load a speaker presents. Most likely they are 4 Ohms.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 17, 2001 | 11:32 AM
Frank88's Avatar
Yeah, I dug around under the carpets and found the stock wiring. Reconnected these and left the subs unused for now. I'll worry about them later - too cold outside now, can't wait for spring and start driving this car again.
Caspar
Jun 19, 2016 11:19 PM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 13, 2015 07:36 AM
