Fm Modulator
an FM Modulated CD Changer is a regular CD changer that hooks up to the FM radio in your car. Its what i got hooked up to my Berlinetta Radio. It comes with a separate controller to change tracks and discs with, which you have to mount yourself somewhere.
Its a lifesaver if you want to keep your car stock and play CD's.
I added some amps to power the 6x9 and 4x6 and bought some subs and all my friends say it sounds good. It is easy to install, ive done it before. But for my car i went to Best Buy cuz i didnt wanna screw it up
kev
kev
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you buy a separate FM modulator, you can use it with any device that uses normal RCA outputs, including a portable cd player. The way it works is that it hooks in-line with the antenna just like Myposcamaro said. It modulates the audio on a high frequency carrier just like your local FM radio station does, and puts it on the antenna line, just like an FM radio station (well, sorta). So, let's say the modulator puts it on an 88.3mhz carrier. As far as your radio is concerned, it's just a normal radio station at 88.3mhz. So, you tune the radio to that frequency, and you get the sound in exactly the same way you would from a normal radio station.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
i got my Pioneer 6disc changer at Best Buy for $230. The prices went down now, i think that same one is only $199.
But with installation and all that other bull****, it came out to like $300
quite pricy, espcially when your not getting the quality of a head unit. but like i said, if you want to keep the stock unit and play CD's.. its your only alternative
kev
kev
yo, the FM Modulator is worthless with out the CD changer. so you need an FM Modulated CD changer
there are 2 kinds of changers. a changer that you can control with the cd player you had put in your car, and the other is a changer that you can control with a separate Remote which you mount somewhere which hooks into the stock radio.
basically, all the FM Modulated CD changer is doing is playin through a radio station.
A normal cd changer plays through the upgraded cd player and is controlled by the cd player's controls..
i cant explain it any better, sorry
kev
kev
Modulators are not worthless without the changer. There are plenty of stand-alone modulators available that work great whenever you need to feed an audio signal into a deck that doesn't have aux inputs.
The IROC Homepage
The IROC Homepage
Any car audio store can get you one.
The IROC Homepage
The IROC Homepage
keep your eyes on the ads in the sunday paper, esp. walmart and sometimes circuit city. They sell 6-disc changers with rf modulators and everything else you need(besides antenae adapters) for only $100. They're not brand name, but I just wanted to play cds and it works great for me.
