Radio Antenna
Old May 18, 2020 | 04:55 PM
MINT's Avatar
Car: 1987 IROC Z
Engine: Swapped 350 SBC, L89 Cam, OBD2 TPI
Axle/Gears: Stock .323
Radio Antenna
Back in the fall, I purchased an '87 IROC with a carb 305, and a previous owner decided to do this to the Antenna (see pic). I have a "replacement" off a parts car, and I'm unsure if I should use the parts car one, find a motorized replacement, or buy a new one from rock auto.
I'm also unsure of how to take off the old one and put in the new one.
Old May 18, 2020 | 06:47 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Radio Antenna
Which ever antenna you use, they all mount similar (power and fixed) as shown in the attachment.
Old May 19, 2020 | 12:00 AM
Drew's Avatar
Re: Radio Antenna
All the garbage on the top of the fender should unscrew, then the base is bolted inside the fender. Pull the fender liner and you should see the mount behind the fender. The only catch is if someone hacked up the fender for their goofy aftermarket antenna.
Old May 19, 2020 | 01:23 PM
ksr's Avatar
ksr
Engine: 5.7 liter V-8
Transmission: 4 speed auto
Re: Radio Antenna
Pain in the butt replacing those motors. So much easier when they were in the trunk.
A lot of people seem to go with the fixed mast, but personally I'd get a new motor.
Old May 19, 2020 | 10:17 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Re: Radio Antenna
You probably dont need a new motor. You can purchase a new mast for it. If the motor whirs then the mast has a broken plastic runner inside. Pull the motor and look first.
Old May 20, 2020 | 12:02 AM
Drew's Avatar
Re: Radio Antenna
Power antenna is just one more gizmo to maintain and fail.
Old May 20, 2020 | 06:44 AM
ksr's Avatar
ksr
Re: Radio Antenna
That wasn't my experience years ago. Both of my past Formulas eventually had the whirring motor. I replaced the motors and the antenna then worked fine. I never took the old ones apart, but I'd suspect that it was something similar to the headlight motors, where the internal bushings have disintegrated.
I think it looks better with the antenna that disappears when the car is off. It's an annoying repair, but do it and then you won't have to worry about it again for a long time, especially if like most third gens they really aren't getting that many miles piled up on them now.
Old May 21, 2020 | 06:12 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Re: Radio Antenna
How do you guys feel about a hidden antenna? Under the dash maybe?
Old May 22, 2020 | 09:19 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Radio Antenna
I have one in one of my cars. It recieves only FM stations. I am thinking of getting one for my thirdgen, and would mount it in one of the rear hatch compartments with an extension cable. I think that big back window would allow better reception...
Old May 22, 2020 | 11:12 AM
ksr's Avatar
ksr
Re: Radio Antenna
The best solution. Except for the antenna hole up front.
Lauer
Car Audio
Jun 4, 2018 12:07 PM
stalin05
May 1, 2005 03:18 PM
N8MAN1068
Car Audio
Feb 20, 2002 09:56 AM
86_Dan_Z28
Car Audio
May 20, 2001 11:10 AM
89 CamaroIROCZ
Car Audio
Mar 12, 2001 01:53 AM
