More updated install pics...
Old Jan 16, 2002 | 02:13 PM
GndPrx's Avatar
5 pics, each about 11k so it shouldn't take too long to load.
First 3 are the kicks finished except the grill and the last two are center console/radio housing as well as a partial shot of the almost ready to vinyl drivers door.
Old Jan 16, 2002 | 02:27 PM
89transam's Avatar
Those look tight..u made them?
Old Jan 16, 2002 | 02:28 PM
GndPrx's Avatar
One more pic of the initial 1/0 to 4awg power distrobution blocks...
This is where all of the main power and ground feeds split off to the misc fuse blocks and such...
Old Jan 16, 2002 | 03:08 PM
DJSexay's Avatar
lookin good! Will you make SBN ?
So you ended up vinyling the kicks ? I'm going to attempt to make mine with SEM texture coat, but then make a mold off of it and remake the kick with gelcoat to duplicate the texture, should be more durable then sem texture coat.
I should have more pics of my hatch area this weekend or shortly after.
mike
Old Jan 16, 2002 | 03:28 PM
GndPrx's Avatar
89transam - Yes I do all my own work
DJ - Be there as a spectator, most likely, as a competitor, not a chance in he||
I am currently among the ranks of the unemployed, so I don't have the money to spare on all of the rest of the drivers that I need, and most of my time is dedicated to finding a new job so the install is seriously time hindered.
I just have a new digi cam, so I figured I'd get some good shots to post up.
The vinyl was actually pretty easy to do with the HF series and heat activated contact cement from Select.
The hardest part was the wrap around the trim near the door and I found by the second one that if you do enough releif cuts on the back side where it would wrap to the inside, you can pull just enough out of it to semi keep the texture in shape and not burn through.
The HF vinyl is pricey though and even though I really ought to re-cover them, I'll leave them like that for now.
Old Jan 16, 2002 | 03:45 PM
un4givin89's Avatar
Looks awesome, custom doors and kicks I see, made by yourself? Excellent work man. Looks tight, look forward to more pictures!
Old Jan 16, 2002 | 03:59 PM
DJSexay's Avatar
No kidding. It's costing me a small fortune to vinyl my hatch trim panels that I made to cover amps, distribution, etc ...
Look me up when you get there. Come hell or high water, my car WILL be finished.
mike
Old Jan 16, 2002 | 06:53 PM
deadtrend1's Avatar
and the 4th gen console, ive gotta get me one of those.
~Tim
Old Jan 17, 2002 | 12:10 AM
jobryan26's Avatar
Those kicks look sweet and like it was a PITA to Vinyl. What did you end up doing about the dash / door panel problem? I couldn't really tell from the pics. Looks very good. I don't care much for the Plexi around the Headunit tho. It kinda looks outta place but everything else looks great!
Old Jan 17, 2002 | 06:32 AM
un4givin89's Avatar
Is that a mirror you used there?? Cuse it looks like it. Kinda tacky if ya ask me.
Old Jan 17, 2002 | 09:10 AM
GndPrx's Avatar
I'm not sure where you are seeing a mirror...
The black plexi is the same as what is being used in the amp rack, processor rack and most of the trim work. It may look out of place at the moment because it is not secured back in the radio pod, it's just placed over the front for the picture.
Old Jan 17, 2002 | 01:17 PM
un4givin89's Avatar
Its shiney and reflective, thats why i thought it was a mirror
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
86IROC112
Aug 17, 2015 07:57 PM
bryan623
Aug 10, 2015 11:33 AM
