Power Antenna Stuck On and Replacement Radio
anyone know of a good power antenna replacement? mine is stuck in cycle mode mast does not move so currently disconnected, OEM has one
I've read you can re build these but would prefer to buy a new higher quality version if available
Also looking at replacing the factory cassette player to CD but would like something that looks more original to the car if available, thanks
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Power Antenna Stuck On and Replacement Radio
Car: 90 Formula / T-tops
Transmission: MD8
I drove over to Barney's house where he does the repairs and saw his setup. Great guy. Send him an email. He also fixes pop up head lights.
Axle/Gears: 10 Bolt 2.73 Open
If you want to peak at what I went through doing mine (and a lot of other side projects at the same time), you can see that HERE
