flush mounting radio
Old Jan 18, 2002 | 09:47 AM
imokureok4's Avatar
yesterday i recieved the flush mount kit i ordered that is made by scosche. it is a special kit made for camaros and firebirds that will fluh mount any radio, so when i put it all in my 87 camaro te radio wont go all the way in, due toeither a metal bracket holding the sides of the console together or these plastic hump looking things coming off the console im not sure which but those look like they are in the way, ive seen the radio flush mounted before, so how can i get it to fit??
Old Jan 20, 2002 | 10:52 AM
Chevy83Z28's Avatar
You have to take the metal bracket out. In my car, the heater ducts in the console were also in the way, but I just put pieces of 2x4 wood under the console (prying each side out a few inches from the bottom,) put the radio in, and took the wood out. It worked fine for me and the only thing I had to modify was the bracket (not really modifying either... it can go back in if I need it to.)
Old Jan 21, 2002 | 03:03 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
where dd u get the flush mount kit and how much as it?
mike (loomdog)
Old Jan 21, 2002 | 06:42 AM
deadtrend1's Avatar
i spent about a hour with the blade going to a hacksaw, and a contractors glove to hold it so i would slice my fingers. I cut all the plastic under the heater controls and unused metal in the back so i could get everything to fit decently.
~Tim
Old Jan 21, 2002 | 07:26 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
In the camaro all you need to do is remove the metal bar that supports the back of the factory radio. In the firebirds, you've got major surgery to do. I removed the radio console from the car to do the work in my Firebird. It allowed me to do a much neater job.
Old Jan 21, 2002 | 10:49 AM
imokureok4's Avatar
I got the flush mount kit from sounddomain.com it was only 6 bucks plus shipping.
Old Jan 21, 2002 | 06:33 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
imokureok4, was the kit from sounddomain.com part number GM1516. This is the one on the second page for the installation kits, als the one I ordered. Or is there a special flush mounting kit.
Here is the link of the one I purchased. Scosche GM1516
Thanks,
Jesse
Old Jan 21, 2002 | 07:39 PM
loomdog32's Avatar
Car: 82 Camaro Z28
do u have the kit installed in ther car? how does it fit?
i looked at the page and it said 82-96? when i say the 96, i got my old mounting bracket from my 96, and it was barly too big. i almost got lucky there for a min.
mike (loomdog)
Old Jan 21, 2002 | 07:55 PM
oldblueZ's Avatar
Car: 85 Z28
I have not installed mine yet. I just ordered it yesterday, before I read the post, now I am excited to see what it looks like.
EDIT: I ordered my entire system yesterday. My projected install date with my buddy is Sunday, Feb 3rd. I am going out to the field(ROTC stuff) on the 2nd, and because of school I can't do it during the week. I will DEFINATELY get some pics up because my roomate has a diggy cam. If I can, I will try to get a pic of what I am going to have to cut in the back of the pod. We'll see. I am going to post the pics in this thread too.
What I bought:
Kenwood KDC - MP8017 CD/MP3 player
Kenwood KFC - 6908 6x9's
Infinity 6422 CFP 4x6's
Later,
Jesse
Old Jan 21, 2002 | 09:51 PM
imokureok4's Avatar
yts part number 1516 it is made especailly for camaros i havent put mine in cause since the adio itself wont fit ino he dash flush im gonna have to move the support and stuff from inside the console, but i put my cd in the kit to see what it looked like, looks awesome with my radio there is some spaces around the outside of the radio,but it migh just bethe radio the oe i have now is just temporary till my camaro is completed and i put the real stereo in.
Old Feb 4, 2002 | 08:24 AM
oldblueZ's Avatar
Car: 85 Z28
WOW! I just installed my stereo yesterday. The scosche installation kit IS a flush mounting kit. It looks sweet, it's even texturized like the rest of the plastic. I don't know if the brace was already cut in my car because I did not have to cut anything, the head unit just slipped in, llllliiiiiiiiiiiiike a glove. (best Ace Ventura voice). I have a Kenwood and I think that these are a little longer than the others, so my car might not have the brace in it. :lala:
I don't have any pics of it yet. Hopefully in the next couple of days.
Like we said before, the kit was only $5, so if you want to flush mount your stereo without making the panel yourself or spending all of your money on a custom install, then this is the way to go.
Later,
Jesse
Old Feb 4, 2002 | 06:39 PM
Belker's Avatar
I have a '91 Camaro, use the scoshe kit that is adjustable, and am using a Clarion DRX8575z. I can almost get it flush but am sure that the heating ducts behind the HU are the limiting factor. Maybe that HU is deeper than ones being used by other people. The solutions that I've heard are to either cut out the ducts making them non-functional (not a good alternative for cold weather apps), or to carefully take a heat gun and heat the ducts until they are just barely flexable then push on them with a hunk of 2x4 until you have just enough clearance for the HU. I haven't tried this yet. Good luck.
Old Feb 4, 2002 | 08:18 PM
oldblueZ's Avatar
Car: 85 Z28
Belker,
When you test fitted the HU into the kit when it was out of the car did it fit correctly???
If so, did you not lock the kit to the HU when you installed it? That would prevent the entire HU and kit from being screwed in.
There was some talk in here about a bar that is needed to be cut. See if there is a bar that you can cut away. If the heater ducts are the problem, I would not cut them if I were you, try to bend them if you can.
Later,
Jesse
89 formula TPI
Oct 6, 2015 08:40 PM
studebaker60
Sep 7, 2015 12:36 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
