Camaro Double DIN radio brackets from Screaming Chicken
Old 10-09-2023, 11:18 AM
  #101
TABBOO's Avatar
Car: 87 T/A
Re: Camaro Double DIN radio brackets from Screaming Chicken
That is great news. Will the finished bezels have the tron pattern?
Old 10-09-2023, 11:33 AM
  #102
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
That is something the supplier is working on. They will be more expensive to produce so we might offer a bezel with a texture and another with the tron pattern.
DynoDave43 (10-13-2023)
Old 12-30-2023, 11:27 AM
  #103
Klynsma76's Avatar
Car: 1986 Firebird
Engine: 350 SBC
Transmission: TH350
Axle/Gears: 9bolt 2.73
Any updates on the 85-92 firebird bezel kits? Thanks!
Old 12-30-2023, 04:09 PM
  #104
scfbody's Avatar
2 issues so far that are holding up that product:
- The radio pods I have are in rough shape with busted mounting tabs. New reproduction pods might be something available in the near future thru a supplier and I'm also looking for one in better shape thru Ebay and other sellers.
- The grid pattern and finish doesn't print well enough, that is something the bezel makers are working on still. Would be possible for the bezel to have a finish similar to the Camaro, but nothing that would match the original bezel.
Old 12-30-2023, 04:36 PM
  #105
Klynsma76's Avatar
Car: 1986 Firebird
Engine: 350 SBC
Transmission: TH350
Okay, I'm not to worried about having the grid pattern or not. So if I pick up a set of your brackets and acquire my own bezel for it would I be good to go?
Old 12-30-2023, 04:40 PM
  #106
scfbody's Avatar
Current Camaro brackets do not fit 1985-92 Firebirds unless you drill holes and modify the brackets a lot. Once I can find a Firebird radio pod without broken mounting tabs we plan to make Firebird brackets.
Old 12-30-2023, 04:44 PM
  #107
Klynsma76's Avatar
Car: 1986 Firebird
Engine: 350 SBC
Transmission: TH350
Oh darn, guess I'll be waiting in anticipation then lol
Old 12-30-2023, 04:49 PM
  #108
scfbody's Avatar
Every Firebird pod I find is broken up and missing mountings points, which doesn't work well for making brackets that fit correctly. Normally they have at least 3 out of 4 so I can tell the Camaro wouldn't fit without modifications, but that's about all they are good for.
Klynsma76 (12-30-2023)
Old 02-21-2024, 11:42 AM
  #109
Klynsma76's Avatar
Car: 1986 Firebird
Engine: 350 SBC
Transmission: TH350
Finally started working on my firebird and the pod is completely intact! If you want to dm me I wouldn't mind sending it to you!
DynoDave43 (02-22-2024)
Old 02-21-2024, 12:11 PM
  #110
scfbody's Avatar
Awesome! just sent a dm
Old 04-21-2024, 12:27 PM
  #111
TABBOO's Avatar
Car: 87 T/A
Any updates on the bezels and brackets?
Old 04-22-2024, 08:34 AM
  #112
scfbody's Avatar
Using the pod Klynsma76 sent me and working on brackets currently.
Old 04-22-2024, 09:57 AM
  #113
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
I'm in the process of getting the firebird molds quoted as well as working on the last 20% of the 20 ton mold machine.
scfbody (04-23-2024)
Old 04-22-2024, 07:31 PM
  #114
TABBOO's Avatar
Car: 87 T/A
Thank-you both. I know this has been a real project. I am just grateful folks like you are still supporting these cars.
Matt Nelson
Car Audio
02-03-2018 10:23 PM
Golfvette
Interior Parts Wanted
05-28-2013 09:29 AM
jstanfi1
06-28-2011 12:28 PM
djmarch
02-28-2011 03:47 AM
RockyEffE
Car Audio
01-29-2004 01:15 PM
Quick Reply: Camaro Double DIN radio brackets from Screaming Chicken
