Just put a 2nd cap in... MUCH better...
Old Apr 10, 2001 | 03:42 PM
92fire-audio's Avatar
Well I got tired of having to turn my system down at stop lights because of drawing too much current with the rpm's low.. I have a pioneer amp that does 70x2 rms and a rockford 800a2 and a circuitbreaker on the battery (100amp). I also had a 1 farad cap which did NOTHING it seemed as far as keeping my lights from dimming and such. I decided to put another one in and a buss bar.. So far it has made a huge improvement.. I can actually listen to my system now.. If any of you are having charging problems, add another cap (or two) before you go out and buy another battery or a high power alternator...
Old Apr 12, 2001 | 08:14 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
what gauge wire? something isn't adding up here.
Old Apr 17, 2001 | 08:45 AM
purpleworm's Avatar
I agree there seems to be something wierd going on there....I have no prob with mine abd I don't even run a cap.
91 Z28 Camaro
305 TPI
700R4 with 2000 Stall and shift kit
Old Apr 20, 2001 | 04:35 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
how about a higher current altenator and thicker wire?
Old Apr 21, 2001 | 12:30 AM
I've got the stock alternator and battery, with the stock wiring. As far as wiring for the amps, 4 gauge to both amps, 8 gauge to the caps from fused distribution blocks.. This system draws a total of over 100 amps...
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 07:57 PM
