Anyone with a 15
Old May 20, 2001 | 12:31 PM
APCAMARO's Avatar
Anyone with a 15
Right now I have 2 MTX 8000's and they pund hard but im am going to start focusing on making my car faster so i dont want all that or the weight of my box anymore. My ? was does anyone have a 1-15'' setup with pics so i can see how the sub was placed? I think i am going to go with the mtx rfl 15 that holds 4000 watts WOW!
Red 87'Z-28 350 TPI(FORMERLY 305),MSD 6AL IGNITION,GUTTED MAF AND AIRBOX,NEW FALKEN ZIEX's
700r4 w/b&m shift kit and cor. servo
2-12'' MTX 8000'S
Old May 20, 2001 | 03:42 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
How much weight do you think you're going to save by going from 2 subs (what size??) to a single 15"? If your 2 subs are 10s or 12s, your overall weight savings will be no more than a couple pounds. Most 15s need a big box, which requires a lot of internal bracing, plus the sub itself is going to be very heavy.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 21, 2001 | 01:20 AM
KlayBuRn's Avatar
id stick with the 12's man...
Old May 22, 2001 | 12:46 PM
APCAMARO's Avatar
Well right now with my box and amps and subs my box weights over 250 pounds and when I do take it out there is a noticeable difference in performance. Then the fact that it takes up all of my cargo area in the back and I would like to be able to store things back there. I just wanted to make things alittle smaller and simpler without losing much spl... does this make any difference in your reply's ? thanks
Old May 22, 2001 | 05:44 PM
Jim85IROC's Avatar
Nope. Most 15s that I've seen require 2.5 or more cubic feet, so your box isn't going to get any smaller, so the only weight savings you'll have is purely in sub weight, which won't be enough to warrant the expense.
The IROC Homepage
Old Sep 23, 2003 | 01:58 AM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
that sub you want to get the rfl weighs 56 pounds wheres the benifit?
Old Sep 23, 2003 | 08:45 AM
9177's Avatar
If you like music don't buy the RFL. And Jims right unless you build a fiberglass box you won't save much in weight.
Old Sep 23, 2003 | 09:00 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
yeah, the rfl is not made for music, just burps for spl competition. stay away if its a daily driver. you will not save any space and weight is negligable. so stick with the 12s.
Old Sep 23, 2003 | 11:40 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
This guy has not posted since 10-1-2001. So I dont think he is still around.
Old Sep 23, 2003 | 02:41 PM
Jose'sRedTA's Avatar
Car: 87' Red TA w/ 92k miles
haha.......lol
