box materials?
Old May 22, 2001 | 01:37 PM
FTC's Avatar
FTC
box materials?
its probably been asked before but is there a difference between using plywood instead of mdf for a sub box? and also where could i get mdf other than a stereo shop where theyd rip me off. thanx
Old May 22, 2001 | 02:34 PM
admrlam's Avatar
They sell MDF here at Home Depot... If you dont have that store near you, its like a Do It Yourself Materials store... Comparable to Chase Pitkin... They have like, household building materials there.
They have MDF at what seems like a good price, 5 bucks gets you a 2 foot by 4 foot piece, or something around there.
Old May 22, 2001 | 02:36 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
MDF has more sound deadning quality. If you knock on MDF it sounds "dead". That's what you want. If you knock on plywood it's sound like a front door. Not good. You just have to be more careful when screwing corners together with MDF because it's more brittle. I have done my fair share of driving the screw in too far and crushing the edge of MDF. IMO you get better sound from an MDF enclosure. You can usually get MDF, or they just call it fiber board, at Menards, Lowe's, Home Depot, etc. Get a good saw blade too. MDF needs a fine blade, with your saw set shallow.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old May 22, 2001 | 02:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I made some 6x9 boxes a while ago with MDF... that board was rough on my Jigsaw blade. It took the points right off!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 22, 2001 | 04:33 PM
AJ_92RS's Avatar
TomP,
I found that a metal blade actually works best in a jigsaw. I can't count on two hands how many boxes I've built ( I can barely count as it is ). It's all trial and error I guess.
Old May 22, 2001 | 04:35 PM
Mike92RS's Avatar
MDF is also much more pleasant to work with (no splinters ). I got mine at Home Depot, the 2' x 4' x 3/4" sheets. I looked at Lowe's before that and couldn't find any there.
- Mike
Old May 22, 2001 | 05:42 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Mike's right. MDF is such a pleasure to work with. Instead of jagged edges and flying chunks, you just get soft powder. The end doesn't break off as you cut, and the cut is always clean and smooth. I won't use Particle board anymore. I like MDF too much!
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 22, 2001 | 07:43 PM
Belker's Avatar
MDF is the way to go because it does a good job of not adding any sound of its own to the way the box sounds. Also, obviously, many people prefer working with it as a building material for this kind of application.
If you already have some plywood laying around it will be quite adaquate for making a sub box. I'd try to avoid anything thinner than 3/4". Also many SPL competitors use plywood for there boxes because its cheaper and they're constantly changing their box design.
The important thing to remember is that the box design and construction is FAR more important than the material used (within reason). Use bracing. I can't emphasize the importance or bracing in a good box. Make sure all the joints are tight and caulk them on the inside. Use glue and screws every 2-3".
Plywood is fine.
Old May 22, 2001 | 09:18 PM
odin65's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Belker:
Plywood is fine.
</font>
The only plywood you should use is 3/4 birch ply, here in NY it costs about $45 a sheet. The biggest problem with MDF or particle board, for a sealed box, is the edge strength. When you screw into the edge the material tends to split and has reduced gripping power, even when drilled first. The other problem is that if you do not brace very well, or use dado joints, the edge joints will weaken over time due to the pressures in a sealed box.
Old May 23, 2001 | 04:38 AM
9177's Avatar
Make sure you use wood glue. Just using screws makes for a bad joint. The screws are just there for Extra support. I usualy just use a nail gun and then I don't need to worry about smased ends.
Old May 23, 2001 | 07:36 AM
GndPrx's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jim85IROC:
</font>
Heh, I can't believe Jim admitted to using particle board j/k
Carl
CarAudio Resources
Old May 23, 2001 | 09:06 AM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GndPrx:
</font>
I use particle board a lot, despite hating it with a pssion. My local hardware store gets $35 a sheet for MDF and I have to order it, which is a major inconvenience.
The IROC Homepage
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
MrPackstin
Oct 25, 2017 08:09 PM
Zell1luk
Sep 29, 2015 10:36 AM
