Help with alternator
Old Jun 12, 2001 | 02:06 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Who can tell me what alternators are compatable with 87 Camaro Z28. I need to get at least a 120 amp for my system. Will any pickup alternators work? Help.
Old Jun 13, 2001 | 09:18 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
What size system do you have? If you have a V-8 and are running a decent size stereo, you will probably want more than 120 amps.
In my opinion, you are almost better off to have yours rebuilt to your personal specs cause it is often times cheaper. I found a place here in Columbus (OH) that will rebuild alternators for $1 an amp. They do very good work also. A friend of mine had an alternator rebuilt by this company about 3 years ago and it is still going as strong as ever. Also, usually you can get it rebuilt and they will install it and make sure everything is working all within two days.
As far as truck alternators go, all I can suggest is looking at various alternators and see if they have the same bolt system as yours.
Good luck
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
[This message has been edited by IROCET (edited June 13, 2001).]
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
