How to adjust amp & crossover gain together?
Old Jul 30, 2001 | 05:16 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
You might have seen my other post regarding connecting up a crossover box. I've been searching thru the message archives about adjusting gain, and I really haven't found an answer to my question. If I have a crossover box, how would I go about adjusting the gain? I am thinking that I would want to set the gain on the amps to the highest setting and then use the gain control on the crossover to adjust it. Is this how it is to be done?
Old Jul 30, 2001 | 06:36 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Set your amps at 1/2 power. Set your deck the manufacturers preferred output level for EQ or X-over input (if you don't know this, set it to about 2/3)
Then set your X-over from 1/2 to 3/4 (I don't recommend maxing it out)
The idea is to adjust output power at the first amp device (your X-over)...use the actual amps last. It may take awhile to get the desired sound, but just keep tweaking it. Hope this helps
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jul 30, 2001 | 10:22 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Thanks very much, I'll try that once I get my new deck.
Old Jul 31, 2001 | 12:55 AM
Belker's Avatar
[This message has been edited by Belker (edited July 30, 2001).]
Old Jul 31, 2001 | 06:56 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The proper way to do it is to bring the output of the head unit up until it clips, then back off slightly. Then bring the output of the intermediate piece (in this case a crossover) until the signal clips, then back off, then finally raise the gain of the amp(s) until clipping or speaker distortion, then back off.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 31, 2001 | 09:04 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Don't you need an Oscilliscope and tone generator to measure clipping?
Old Jul 31, 2001 | 12:07 PM
Pukka's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jim85IROC:
</font>
So is your system adjusted properly if your amps and X-over are maxed out to begin with and your head unit/speakers start clipping when the volume level is set to...lets say 3?
Your stated intent is good, but you have to turn down everything to at least mid-range before you start.
Old Jul 31, 2001 | 12:20 PM
Jim85IROC's Avatar
I never said to max them out when you start. I figured people would have enough common sense to realize you start low then turn it up to a specific value. Apparently I assumed too much.
An o'scope would be nice but it can be done by ear. As soon as you can hear the distortion, you trim it back to where it's clean and maybe a tad more.
The IROC Homepage
gixxer92
May 18, 2017 11:20 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
