2 ohms?
Old 08-09-2001, 10:05 PM
nicmike85's Avatar
2 ohms?
I have a MTX thunder 302 amp and a pair of 8 ohm 12" kickers. The speakers were cheap. By bridging the 8 ohm speakers in a parallel what am I doing? I don't want to destroy anything and I don't know much about running 2 ohms. Should I buy 4 ohm speakers?
Old 08-10-2001, 02:43 AM
Shawn84SC's Avatar
By connecting two 8ohm speakers in parallel, you create a 4ohm load. If you bridge two channels of the amp the amp will "see" a 2ohm load. This setup will put out the most power.
Old 08-10-2001, 08:57 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
<font face="Verdana, Arial" size="2">Originally posted by Shawn84SC:
By connecting two 8ohm speakers in parallel, you create a 4ohm load. If you bridge two channels of the amp the amp will "see" a 2ohm load. This setup will put out the most power.</font>
Not trying to correct you so much as trying to help him. So read in "open minded" mode, OK? When you bridge a 2 channel amp, like what you are talking about, then that bridged amp will see a total resistance of 4ohms. You are correct on the parallel part. But if you have the amp bridged into a 4ohm load, then each channel of the amp will have a 2ohm load.
Whenever you bridge an amp, you are combinding the 2 channels together (obviously ) and splitting the resistance to each channel. If your amp's owner's manual says that each channel is stable at 2ohms, then you will be fine.
You did good by buying 2 8ohm subs. Better safe than sorry.
AJ
Fanatic1074
10-03-2022 05:57 AM
Elephantismo
02-13-2019 12:51 AM
lewandom
10-01-2015 08:15 AM
ironbmt
09-27-2015 06:00 AM
Shane87irocz
09-22-2015 06:21 PM
Quick Reply: 2 ohms?
