HEREEEEESSS JOHNNY!!!! back.. now, the power wire and engine noise
anyways, while waiting for pickup last week, i tried the alternator pull, run car, pull out wires from alt,. and still, engine noise...
i have the power wire comming out of closest fender 'hole' close to the firewall, im gonna see if i can route it farther in the fender, and have it come out clower to the battery,
any other thoughts guys?
where did you run your rcas? i ran mine up the left side, UNDER theFuse block....
gunna mess with that too....
Thnx,
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Thnx,
91 FireBird 305 V-8
"Honda's FOR ME TO POOP ON!" -Triumph... ad;lfkjsadf;lkjadsf;lkjasf;alskdjfaslkd;fjasdf;lkjsadf;lsdkajfalsk;djfads;lkfjsadl;kfjasdl;fjkdas
thats almost how it sounds............
bttt.
91 FireBird 305 V-8
bttt.
91 FireBird 305 V-8
"Honda's FOR ME TO POOP ON!" -Triumph... Its been plaguing me ever since my system went in... I still haven't solved it.. did you check out my frustration post.. might have some suggestions for ya, here: https://www.thirdgen.org/messgboard/...ML/001838.html
~Luke
'91 Firebird :: 305/TBI/700R4 ::
Mods: Catco cat - Flowmaster 80 series - B&M Shift kit - TA tail lights - GTA rims - K&N - MacEwen guages
Stereo: Pioneer DEH-P8200R - Cadence 4x6's - Pioneer 6x9's - Kicker amps - Kicker 10" CompVR
::R.I.P.::'87 Firebird - Firebird parts - Selling an '80 Firebird for a friend
Moderator of tranny board over at TransAmGTA.com
~Luke
Have you guys tried muting your amps to see if the noise goes away? You can eliminate 50% of the system as the problem maker by doing that.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 5151 150HP kit
Only had one problem with engine noise.. it started whining loudly like i had a turbo or something. turns out it was my alternator dying... A guy i talked to at an automotive place said the factory alternat6or only has enough power to power the factory applications and nothing else, even a new set of fog lights or something drains power and will eventually kill your alternator.
87' Camaro Z28
305 TPI
Stage 2 hypertech chip
Custom ram air w/K&N's
air foil
shift kit
aluminum driveshaft
posi
VST gas ryder gas shocks
3" flowmasters
custom muffler
87' Camaro Z28
305 TPI
air foil
shift kit
aluminum driveshaft
posi
3" flowmasters
custom muffler
ok, i solved one prob, to land in another.....
NOW IT IS THE ALT!!!!!
i unplugged, no more whine, plug in hit gas, louder high pitch,
heres my dancing needle
What else should i see before buying stuff, and what should i buy, how much, and where??
Thanx!
91 FireBird 305 V-8
Thanx!
91 FireBird 305 V-8
"Honda's FOR ME TO POOP ON!" -Triumph... Trending Topics
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 11, 2015 10:11 PM
