EQ and Head Unit Hook Ups.....lost
Old Sep 27, 2001 | 06:15 PM
FrostsZ28's Avatar
Ok i have the new Kenwood KGC-9044 digital graphic EQ and the Kenwood excelon KDC-X911 deck. On the back of the HU I have only 3 pre-outs: Front, Rear, (Non-fade or Sub). Then on the back of the EQ-Unit I have four sets of RCA's. 1 is the Input channel, other 3 are output channels, Rear, Front, (Non-fading). My question is which of the 3 pre-outs on the HU do I plug into the Input channel on the EQ-Unit?
If its not a camaro or corvette then what is it really?
Old Sep 27, 2001 | 09:54 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Doesn't matter. They all play the same thing unless you screw with your fader or set the non-fading set as a sub-out with the built in crossover. I'd say use the non-fading set, but it really doesn't make a difference.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 28, 2001 | 03:05 PM
FrostsZ28's Avatar
But will that mess things up if i try to fade the sound to the front since i have a pretty heavy pounding sub, to be able to hear the highs better?
Old Sep 28, 2001 | 04:18 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
You only need to use either one of your outputs from the headunit to feed the EQ.
Use the EQ for balance and fade control of all your speakers.
I assume that you either have or plan to get some amps (at least 2) to connect your EQ pre-outs to your speakers.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Sep 28, 2001 | 04:41 PM
FrostsZ28's Avatar
Yeah I have one amp on my highs, and another on my sub, all my speakers will be on amps.
Old Sep 28, 2001 | 06:35 PM
Pukka's Avatar
Performance:
Electronics:
Old Sep 28, 2001 | 06:46 PM
FrostsZ28's Avatar
I know I will only have to use one set of RCA's coming from the HU to the EQ but which one? I plan on running the Front and Rear outputs on the EQ to my Kenwood Excelon amp which has A and B channels which will be pushing 2-6x9's and my 6.5" componet set, the Non-Fading channel off the EQ to the Monster Kenwood Excelon amp which will power my 15" sub .
Old Sep 28, 2001 | 07:02 PM
Pukka's Avatar
Like I said.....either output from the H/U will do. Use the EQ as a fader between front and rear speakers
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
ZsTransAm
Aug 11, 2015 07:30 PM
