Can someone Please explain how the distibution block stuff works?
Old Oct 2, 2001 | 05:52 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I have a 4 guage wire with and 80 amp fuse.
I am going to run it to a 4 way distrabution block, and then run 8 guage from there. Now right now I'm only hooking into a Cap, and then to a RF 800.4.
Now here's where I get confused. Int the Distrabution block there are 4 fuses.
1 10A
2 30A
1 50A
Now should I replace all the fuses with a certain size? What size? Same Size?
How much power will go through the block once it go's through the second fuse?
IE. Power goes through the 80 amp fuse travels to the distro block, goes through the 50 amp fuse, how much power is traveling to the amp?
I've been readin all I could, and still finding myself confused, so if someone could please help, I would be greatful...
thanks
Peace, Love, and Carbon Monoxide...
Kj
Old Oct 2, 2001 | 06:46 PM
pianiy's Avatar
Well the distribution block will never see more than 80A but its ok to put fuses with ratings that total more than 80A but not higher than what the electronic device on the other side of the fuse is rated for. Say that 50A is going to an amp that has a max rating of 40A, you should probably replace that 50A with a 40A since its really not doing you any good. Its basically a secondary measure if the fuse on the amp fails for some reason, you've got a backup (dist. block). Just think of fuses as funnels, the larger the funnel opening the more fluid you'll have flowing through it, the smaller the opening, less fluid. Then put an even smaller funnel below the first and it'll act as another bottleneck.
~Luke
'91 Firebird :: L03/700R4 ::
Mods: Catco cat - Flowmaster 80 series - B&M Shift kit - TA tail lights - GTA rims - K&N - MacEwen guages
Stereo: Pioneer DEH-P8200R - Cadence 4x6's - Pioneer 6x9's - Kicker amps - Kicker 10" CompVR
Firebird parts - Selling an '80 Firebird for a friend
Moderator of tranny board over at TransAmGTA.com
Old Oct 2, 2001 | 06:52 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Kewl, so I need to check and see what the max power rating on the RF 800.4 is, right? Then from that make sure that all the fuses are right?
Old Oct 2, 2001 | 11:38 PM
matthew's Avatar
I don't understand why there are different size fuses in the d-block?
yellow 86 Camaro
LG4 700R4
ROH RH 17x9
Bridgestone Potenza RE730 255/45ZR17 all around
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
Old Oct 3, 2001 | 09:47 AM
FiReBReTHa's Avatar
because if you have an amp suckin allot of juice, you will keep blowing a 40 IE. so then if you get a 50 and the amp is still safe and not blowing,
and vice versa.
heres mine.
i love it, 1 gauge in, 4 gauge out...
if ya need install stuff, go to
www.justcaraudio.com
talk to a guy jnamed robert, and tell em that you know me, (rick/firebretha) he's got great prices and i love the stuff.
Gluck. hope i helped
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Oct 3, 2001 | 10:08 AM
pianiy's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kj Rockz:
Kewl, so I need to check and see what the max power rating on the RF 800.4 is, right? Then from that make sure that all the fuses are right?</font>
Yeah, basically. My system for instance, has two Kicker amps. One has two channels and a 30A fuse for each. The MOST that those two will draw is 60A of course so you should put no larger than a 60A fuse in that part of the dist block - you could even go slightly less to be safer.
Different sized fuses in the block could be to power different components. The block is a source of 12+ voltage and you could use it to power any number of accessories in your car, just make sure you use the right sized fuse for those electronics.
Old Oct 5, 2001 | 05:31 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Do you need to ground the DBlock, and if so how do you do that?
Old Oct 7, 2001 | 04:13 AM
IROCketZ28's Avatar
No, the dist. block does not get grounded. Simply one wire in from the batt., 4 wires out to the desired components.
One thing I haven't seen mentioned yet is to make sure the fuse you put in will pop before the wire will. For instance, you wouldn't put a 100A fuse on an 8 Ga wire, as the wire would go first if the amp ever shorted, and that would leave one heck of a mess if it didn't burn everything in the process!
'87 IROC Z28
SS 1-2 in dB Drag, Stk2 in IASCA IdBL
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
AFPR (set @ 46 lb)
TB AirFoil
Grant wheel
Custom short-throw shifter with leather boot
Pyle head-unit, Audio Control Epic-150 (Epicenter, SPL meter & voltage meter), Audiobahn 16V line driver, Autotek 4x100 mid/high amp, (2) Earthquake PH-D2 amps, (2) Shocker Audio 12" Shocker Xtremes w/ dual 1-Ohm coils in a 6.6 cu ft 4th order enclosure tuned to 45 Hz for SPL, 33 Hz for street. Polk/Eclipse front stage. Roughly 4500 W RMS. Good for 152.1 dB so far, shooting for 155 by the start of next season!
Check out my homepage and let me know what you think!
http://hometown.aol.com/ldaly33569/m...e/profile.html
IROCketZ28@caraudioclub.net
[This message has been edited by IROCketZ28 (edited October 07, 2001).]
1992rs/ss
Jan 31, 2025 05:10 PM
Jake_92RS
Jan 28, 2020 10:37 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
