Need Help with subs
Old Oct 18, 2001 | 03:04 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
Need Help with subs
I have an 86' camaro sport coupe and i can get 2 15" cerwin vega subs for $300cad and i was wondering if i can get a box to fit them in my car.
Old Oct 18, 2001 | 03:06 PM
FrostsZ28's Avatar
I have a friend that took the box for 2-12's that fit in the well and cut the holes to make it fit for 2-15 RF XLC's and it slammed pretty good.
If its not a camaro or corvette then what is it really?
Old Oct 18, 2001 | 05:40 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
You should. I saw a Camaro for sale a few months ago with four 15" Vegas. He had the back seats removed and sat the boxes on there. However you can make a box that will fit in the well. I'm not sure if the part that is 15" will fit in the well but you can put it at an angle or make it stick up a bit.
-Matt
1984 Camaro Z28 - Black w/ Grey int.
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, AC Delco wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrome valve covers, breather, and Air cleaner.
-Profesionally Built Turbo-350 with Hurst shifter & B&M shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat. & Paint: Navy Blue Metallic w/ Silver strips
Pics at: http://members.fbody.com/flashz28/
Old Oct 18, 2001 | 06:05 PM
FrostsZ28's Avatar
the box that my friend is on this site http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1285048957 cept he took the 12" holes and cut them for 15" and they fit just fine in the well.
Old Oct 18, 2001 | 06:17 PM
Car: 1986 Camaro SC
can you buy the angled boxes in stores or would i have to order them??
Old Oct 18, 2001 | 06:38 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Hey 86SC! Nice to see a fellow Nflder on the Thirdgen board! I am looking into making a box for my Iroc...I am doing a lot of research..emailing people, etc... if I come across a good design I will let you know.. let me know your email addy!
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
"Better to look at it than to look for it "
Old Oct 18, 2001 | 07:00 PM
Car: 1986 Camaro SC
[b]my email is jhutch1@nf.sympatico.ca
where in nfld are you from
Old Oct 18, 2001 | 08:44 PM
87ROCZ's Avatar
St. John's
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Check out my ride in the Readers Rides
https://www.thirdgen.org/rides/index...ew&rideid=6920
Old Oct 19, 2001 | 07:02 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
15" vegas need something around a 3 cubic foot box. A pair would need a total of 6 cubic feet. Add in the dimensions of the wood and bracing, and you wind up with a box that's absolutely gigantic. Those Vegas sound great and hit hard as hell, but they take up way too much space. If you put them into a smaller box, they'll sound like hell.
The guy that stuffed the 15s into a 12" box most likely wound up with a system that slams at 1 frequency, but is thick and muddy sounding, and has no output except in that narrow frequency window. If all you listen to is rap it's not so bad because all that crap booms at the same frequency anyway, but with real music those types of setups sound real bad.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 19, 2001 | 01:48 PM
Undrtkr25's Avatar
I agree with Jim. The box needed would be much too big. Use the 300 bucks for a set of 10" or 12" Subs
'89 Chevy Camaro
305 TBI
COMPLETELY stock
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
