actual amp wattage
Old Nov 18, 2001 | 09:54 PM
84berlinettaV6's Avatar
actual amp wattage
I was just wondering if there was any way to tell how much power my amp is actually putting out. This could come in handy when tweaking my system for more power. Thanks for the help.
Old Nov 19, 2001 | 07:12 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Not really. Your best indication would be current draw on the system. You can buy inductive ammeters fairly inexpensively.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 19, 2001 | 09:59 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Measuring how much current your amp is drawing and multiplying that by the voltage at your amplifier should give you a roundabout figure of the wattage your amp is putting out.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
Old Nov 20, 2001 | 01:16 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
You really don't need to worry about the actual wattage, unless your going compete. You just need to know that it sounds good at whatever volume that you want. If you want bragging rights, go with the rated wattage.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Nov 20, 2001 | 07:20 AM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RSpeed:
</font>
Not really. You'll be able to calculate how many watts the amp is consuming, but not how many it's sending to the speakers. Amps are not 100% efficient, and to complicate matters, their efficiency changes with the output level.
If the speaker had a constant resistance, you could calculate the power output, but because a speaker is reactive, it's not possible without a bunch of expensive test equipment.
The IROC Homepage
Old Nov 20, 2001 | 07:54 AM
Thanks guys. I guess the best way to tell is by ear or maybe even a decibal meter.
Old Nov 20, 2001 | 03:01 PM
stingerssx's Avatar
There you go.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
FormulasOnly
Oct 2, 2015 05:52 PM
raymondandretti
Sep 27, 2015 06:43 PM
