replacement for the quadrajet
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
Im just wondering, my quadrajet is acting up and im interested in buying a new carb, but what would be a good replacement for it? What kinda price range would i be lookin at?
87 z28
305 4 barrel carb
87 z28
305 4 barrel carb
Transmission: 4L80E/4L80E
There is only one replacement for a computer controlled q-jet - a computer controlled q-jet. If you are in an emissions inspection/testing area, you will fail with anything else.
If you are not in an emissions inspection/testing area, you can make other carbs work - but the one mentioned above will not bolt to your intake manifold. If you get an older q-jet or new Edelbrock q-jet, it will not have the computer control features, so you will need a mechanical/vacuum advance distributor, non-CC AIR and EGR valves, and some way to make your torque converter clutch lock up (if auto). Also, your SES light will stay on without the CC inputs, so you'll need to take out the bulb.
Quite honestly, it will probably be easier and cheaper to figure out why your q-jet is acting up and fix it. If you have to deal with emissions, you have no other choice.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
There were just enough differences between this and the last person who asked to type it all out again. Perhaps an FAQ on this forum would help.
Not to flame, but the message is, "Do a search before you post a topic."
CHP is doing a series on an '87 LG4 Camaro that they're going to try to get 4th gen performance out of, while remaining emissions legal. I, for one, am looking forward with interest how they'll handle the carb & intake.
Car: 2002 SOM z28
Are you serious? LG4 ---> 4th gen performance? I am hoping that is the 6-cylinder version and not the SS... I will also keep a lookout for that issue.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
They're serious, but they'll probably use a 350. It sounded like they'll stick with the CC carb, though.
They're calling the series "My Generation Camaro".
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
CHP is still using the 305 in the August issue. Biggest additions appear to be an Edelbrok manifold and Corvette dual snorkel outfit this time around, with some exhaust work, timing and carb monkeying in the first column. Now they are into the 16s.
Their first story was what inspired me to get a 3rd gen Camaro. I used to have a 68 Camaro about 25 years ago and sometimes still dream of driving it around, as if it were my personal fighter plane. (Blame that on the original Star Wars, which came out about that time
Anyway, I just LOVE my "new" 86 Camaro Sport Coupe, with its hearty little 305 4bbl, 4 speed Auto, air conditioning, power windows, etc. It is running really well now and is mechanically very sound. Only thing is the rough idle when it's in gear at a stop light during the rain. Some kind of ignition leak I guess.
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
Hey guys, what is CHP? I have the 87 Z28 with LG4 & am interested in what they're doing.
1987 Z28 Black & Silver 305 LG4/5-Speed . . .
NRA/AMA/FOP/IUPA/Blue Knights
Chevy High Performance, a monthly magazine. www.chevyhiperformance.com
Not to be confused with California Highway Patrol - That's CHiPs.
Car: 1987 Z28
Engine: LG-4 305
Thanks, I knew about CHP=California Highway Patrol, & I couldn'g remember (getting old) about the mag!
colton_carlson
Mar 8, 2019 12:21 PM
1987, 305, barrel, camaro, carb, carbs, carburetor, good, holley, lg4, nonemissions, qjet, quadrajet, quarajet, replacement
