drinking gas
Old Apr 18, 2002 | 11:15 AM
speedfreaker's Avatar
drinking gas
my car has been drinking gas real bad and i have been taking it easy on it alot lately as well can anyone help me out with de tuning my qjet to run for maximum gas milage i have no idea how to do this thanks
Old Apr 18, 2002 | 06:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Tell us a little more about your setup. You say "quadrajet", but is it computer controlled, or mechanical? You say "no smog equipment", but if the carb is computer controlled, you at least need an O2 sensor. If you have a non-CC carb on there, what distributor do you have? The CC distributor won't do you any favors with a non-CC carb.
Fill us in a little more, and we'll give it a shot.
Old Apr 19, 2002 | 10:50 AM
well the carb has wires going in it so i assume its computer controled i have the stock distributer but new wires cap and rotor im gonna check my o2 sensor the car is pretty much basicaly a stock 83 trans am besides the performer rpm intake all smog removed "except o2 sensor" so hopefully this helps
Old Apr 19, 2002 | 11:45 AM
five7kid's Avatar
The carb should have a connector on the top passenger front corner, front driver's side corner, and a single wire to the choke. If so, that's a CC carb.
The distributor should not have a vacuum canister on it, and two sets of wires coming from the base - one going to the distributor cap, the other a 4-wire flat connector going to the engine wiring harness. If so, then it's a CC distributor.
The timing should have been set with the flat 4-wire connector disconnected. If not, your timing will be extremely retarded, and poor gas mileage will result.
Is this a Performer RPM q-jet manifold? I haven't heard of an EGR version of that. I doubt that's a problem, although the ECM will want to see the solenoid or it'll set a trouble code. I've heard of guys just plugging in the solenoid, but not have any vacuum lines going to it.
Any lights come on yet?
Old Apr 22, 2002 | 11:24 AM
sorry it took me a while to reply i had high school prom to go to anywayz i guess its a cc then 4 wires and all
so you say i should disconnect the 4 wires from the distributor to the computer {it wolnt hurt it haveing the comp disconnected wile the motors running??} also the perfermor rpm doesnt have the egr its completely removed no warning light in the dash yet and it runs pretty decent and strong for an old car and motor though it just insanely drinks gas
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
customblackbird
Oct 1, 2015 04:30 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
