800 CFM too much for LG4?
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I am about to put a 79 corvette carb on my 84 firebird and I want to know how feasable the 800 CFM max will be, is it too much ?? I also want to know if there is a way to lower it to 700 or so and what kind of tool would I need to evaluate the actual amount flowing in?
Am I putting up too many posts?
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here $1600!!
First Kill: 2001 Subaru Impreza WRX Wagon (1 person vs me with 2 passengers)
[This message has been edited by ChillPhatCat (edited August 15, 2001).]
Transmission: 4L80E/4L80E
Humm, all the carb guys must be out sick today...
I doubt a '79 Vette q-jet would actually flow 800 cfm, but even if it did, the beauty of the q-jet is that it will adjust itself to work with smaller demand (i.e., smaller engine). Just tune the secondaries with rods/hanger and AV adjustment.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
But I have a firebird... not a camaro J/K (about the difference)
How much does the q-jet on 350 CID third/second gens flow?
[This message has been edited by ChillPhatCat (edited August 18, 2001).]
The Q-Jet came with two different size primary venturis. I know the 850 CFM had the bigger primaries. But most all Q-Jets had their CFM ratings limited by how far the secondary air valve was permitted to open.
There is a tang on the passenger's side that sticks out and limits how far it will open. Cut that off or bend it so the air valve top can open completely.
Personally, I would have rather looked for a Q-Jet whose carb number started with 704**** or 702****. Your 1979 carb probably has something like 1709****. Those "170" Q-Jets have wide taper primary metering rods calibrated for EGR. EGR really muddies the part throttle response but disconnecting it will bring on lean detonation because of the wide taper. I haven't seen too many performance narrow taper primary metering rods for the 170 Q-Jets. The older "70" Q-Jets can accept the older narrow taper metering rods, thereby allowing you to enjoy the linear response of a non-EGR engine and no pinging.
All is not lost however! You probably have the aneroid altitude compensator on your Q-Jet. It's on the right front corner under a cone shaped thing. Pry the dust cap out and turn the adjusting screw about a half to 3/4 turn counterclockwise. This will richen up the main metering circuit and slightly reduce the effect of those wide taper primary metering rods.
I'd still keep my eye open for a pre-EGR 70-series Q-Jet though!
Car: 4
Engine: 6
Transmission: 5
It's fine. It's a Q-Jet. It has an air valve, that won't open any farther than the engine can suck it open; it's self-regulating.
OBTW that carb will have a number starting with 1705; its rods & jets interchange with all the older ones. Like the other post said though, a pre-emissions Q-Jet is a whole lot better of a basis for a fast car than that one; those cars were such pigs.... I remember how much fun it was smoking them all by multiple car lengths with my L69 car when I got it, which was about a 15 sec flat car.... that 79 Vette was probably rated at 180 HP tops, the L69 was rated at 190 out of a 305, in a 300 lb lighter car. That should give you a good idea of how pitiful a late 70s 350 Vette was.
If you're ever looking around in a boneyard at old Q-Jets, the one to get is 7029202, it's off of a 69 or 70 350 with double-hump heads. You find them alot in Impalas and especially station wagons.
The correct tool for calibrating a carb is a track. You can do a good bit of work with a vacuum gauge, a speedo or tach, a stopwatch, and the readily available butt dyno.
ICON Motorsports
ICON Motorsports
sreZ28
Oct 22, 2015 08:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
