PUMP CAM
Old Sep 1, 2001 | 12:56 PM
Federico's Avatar
PUMP CAM
I've just bought a yellow pump cams:
in witch hole should i put it to get the best performance? the first,the second or the third?
Holley vac. sec.with edelbrock performer int.
Old Sep 1, 2001 | 04:30 PM
Jester's Avatar
For you..any cam will probably work best in the first position. the others are for cars with a much higher idle.
Old Sep 2, 2001 | 10:51 AM
Federico's Avatar
Sorry for the stupid question but for "first position" you mean the hole marked with the number 1 ?
thanks
Old Sep 3, 2001 | 03:46 AM
Federico's Avatar
I know that's is a stupid question but i need to be sure
Old Sep 3, 2001 | 01:40 PM
Damon's Avatar
Yellow? I'm looking at a very old Holley book right now but that color shows as a Holley 4500 (Dominator) pump cam only, and only one position is specified.
Anyway, are you sure about 3 holes? There's 2 positions on every Holley I can remember workign on that match up with 2 holes on the throttle arm. Position #1 lines up with hole #1, and if you rotate the cam ever so slightly, Position #2 lines up with hole #2.
And if it's a vacuum secondary carb it will only have a pump cam on the primary side of the carb.
Have I been away from Holleys too long?
[This message has been edited by Damon (edited September 03, 2001).]
Old Sep 3, 2001 | 02:54 PM
Federico's Avatar
yeah damon you hve right, n.1 in the pump cam coincides with the n.1 hole on the trhottle ar, and so the n.2. But in wicth hole should i put this faded yellow pump cam?
Old Sep 4, 2001 | 01:24 PM
Federico's Avatar
Ok hole number one, but in wich direction?
the pump cam has two faces one is plain and the other has the number 1,2,3.
i think that the throttle linkage have to be in contact with the plain face of the pump cam.
IS THAT RIGHT?
YES OR NO?
Old Sep 6, 2001 | 10:38 AM
Federico's Avatar
PLEASE!!!!
Old Sep 6, 2001 | 10:51 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
YES..That sounds right to me.If I remeber my Holleys correctly that is how it goes.That is how it goes on my Demon anyway.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Sep 6, 2001 | 03:17 PM
Federico's Avatar
THANKS!!
Old Sep 7, 2001 | 01:26 PM
greearhr's Avatar
The hole position affect the total volume of fuel delivered. I don't have a reference book handy but you basically have three diferent cams there. It's probably going to be a large shot in any of the holes.
Bear Tracks
Old Sep 7, 2001 | 01:39 PM
Federico's Avatar
Ok .. i unserstand that, you think that the number 1 hole should work for my car?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
