Can the choke be removed from a Holley 4160?
Old Oct 9, 2001 | 10:35 PM
Ernie's Avatar
The butterfly on my Holley 4160 is gone,
has been. So can I take the rest of the
choke off the side of the carb, to make
it look less clutterd, or does it have another funtion beside controlling the
butterfly?? Thanks for your help..
86 T/A L98 with T-5(orig an LG4)
Hooker headers
Performer RPM intake
holley 750cfm carb
cast iron 76cc heads with
2.02-1.60 valves
B&M ripper
Richmond 4.10's
Flowmaster
9.43@74mph 1/8 mile.
Old Oct 9, 2001 | 10:50 PM
Jester's Avatar
nope..no reason why not. Removing it even helps flow through the primaries a bit. Go for it.
Old Oct 10, 2001 | 07:33 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
There is a hole you have to plug if you remove the choke. Its kind of hard to explain where, but I'll try. Where the choke mounts, there are, I think 3 holes besides the mounting holes. I believe it is the hole that is furthest rearward. Don't quote me on this. In fact, when I get home tonight, I will look on mine, and let you know which one if no one else gets it first.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust,Dynomax Bullet Mufflers, T&R Motorsports custom air intake
Old Oct 10, 2001 | 09:45 PM
Jester's Avatar
He has a point..I complely forgot about that.
I vaugly remember having to do that the last time I cut a choke off. I think it was the rearmost hole that holds the choke housing onto the side of the carb. It creates a vacuum leak if there wasn;t a screw plugging it. You can check all of them when you have it off tho..
Old Oct 10, 2001 | 11:28 PM
johnsjj2's Avatar
Car: 1991 Z-28
Okay here is how mine is set up:
0-mount
0 0-mount
0 0-plug this one
0 00
|-mount
I hope this helps a little. If I had my fathers camera, I would post a pic of it. Some of those holes do, of course, have a boss that they are drilled into. I have so many car mags coming in, I can't remember which one said it, but this is the only hole they said needed plugged.
Joshua Johnston
1991 Z-28
Old Oct 10, 2001 | 11:30 PM
johnsjj2's Avatar
Car: 1991 Z-28
Okay nevermind. I can see it didn't work. I will get a digital camera Thursday, and take a pic for you.
Sorry,
Joshua Johnston
1991 Z-28
Old Oct 11, 2001 | 02:30 PM
johnsjj2's Avatar
Car: 1991 Z-28
Well I couldn't find my dads camera. He is in Canada this week, so I won't see him until Saturday. The hole to plug is not the most rearward one. If you look at the side, right about the middle of the carb, you will see 3 holes that are in the general shape of a backwards "L". The one at the top of this "L" is the one to plug. If you look closely at it, it will not be threaded yet.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Old Oct 17, 2001 | 12:53 AM
johnsjj2's Avatar
Car: 1991 Z-28
Here is the plugged hole:
The red stuff is Loctite.
Joshua Johnston
1991 Z-28
Old Oct 17, 2001 | 01:19 AM
johnsjj2's Avatar
Car: 1991 Z-28
Okay, lets try this again:
[img]
https://www.thirdgen.org/rides/rideimages/sma ll_4.jpg[/img]
Joshua Johnston
1991 Z-28
Old Oct 17, 2001 | 01:21 AM
johnsjj2's Avatar
Car: 1991 Z-28
One more time (I'm not too good at this)
[img]https://www.thirdgen.org/rides/rideimages/small_4.jpg
Joshua Johnston
1991 Z-28
Old Oct 17, 2001 | 01:23 AM
johnsjj2's Avatar
Car: 1991 Z-28
At least I know what went wrong:
Joshua Johnston
1991 Z-28
Old Oct 23, 2001 | 05:39 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Why not just put the choke back on?
Ya don't have enough motor to need to remove the choke on a 750 holley (more air flow).
Better yet hook it up! Wait that would be too easy.
Old Oct 31, 2001 | 06:08 PM
Ernie's Avatar
Thanks for the help John, I found it.
What i did was with the motor running
i put my finger on the hole's, I could
feel the suction from one of them.
So i put a pluged in it.No more vac leak.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
