how do you tune an edelbrock?
Old Mar 1, 2003 | 08:00 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i am going to try to tune my edelbrock carb tomorrow and i have no clue how to do it. i dont have a manual or anything because it was on the car when i bought it but i just put in a new engine and its tuned for a 305 and i now have a 350. can somebody please give me directions on how to do it? i tried e-mailing edelbrocks customer help thing yesterday but they havent e-mailed me back. i tried a search but i didnt find much. my carb is a 600 cfm performer. i was also wondering if i should adjust my timing before or after i tune the carb? and what size air cleaner do i need? i have a 12 inch now i think and its too small and i cant put a taller air filter on it or my hood wont close.
Old Mar 1, 2003 | 08:14 PM
bad_ta_05's Avatar
Car: 85 trans am
i forgot to ask if auto-zone rents the air/fuel guage or anything?
Old Mar 1, 2003 | 08:17 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
the manual is online
http://www.telusplanet.net/public/gi...delbrock_1.htm
http://www.cardomain.com/member_page...217306&page=26
Old Mar 1, 2003 | 08:22 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
you don't need an air/fuel guage,
you'll probably only have to adjust the idle and idle mixture screws, and the instructions are pretty clear.
It would make things go quicker if you had someone else there that has run an edlebrock carb. It shouldn't take long at all to get running.
Old Mar 1, 2003 | 08:25 PM
bad_ta_05's Avatar
Car: 85 trans am
i just went to http://www.telusplanet.net/public/g...edelbrock_1.htm and i think i can do it. thanks alot 305sbc
Old Mar 1, 2003 | 11:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Edelbrock has the manual on their website: http://www.edelbrock.com/automotive/eps_intro.html
Old Mar 2, 2003 | 10:57 AM
crazycamaro's Avatar
Car: 89 RS..97 RS..85 Dodge PU
Engine: 89=377,,,97=V6,,,85 PU 318
Transmission: 89=TH350,,97=T5,,85PU 4 speed
If you have any problems shoot me a PM or email.I have a 750cfm
performer series #1411, I bought the rod,& jet & spring kit. it's a pretty simple carb to work on. I have a 14" K & N filter on mine but I also have a cowl hood and it only left about an inch clearance.
Old Mar 2, 2003 | 11:01 AM
I just used a vacume gage to set the vacume at the highest posible vacume. I got 9''~10'' of vacume with a 274duration .50 lift cam.
Old Mar 2, 2003 | 04:42 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Couldn't have really searched far cause me and others
have posted at lenght on the edelbrock.
The online manual at telesplanet is excellent.
You probably will only need to fine tune the primary side.
It's a little rich out of the box.
You can lean it out a bit for economy with a primary jet and metering rod change.
Set you ignition advance first.
Get an advance timing light. Set the timing at high rpm (3500+) to 32-36 deg. with no vac advance ( temperailrly)..
Be sure to rev the motor high enough to reach full mechanical advance while adjusting the timing.
now reconnect the vaccuum advance to ported vacuum. Timing at idle should be 10 to 14 deg @600 rpm.
Do not guess here. Set the timing.
The carb will not be that far off.
Get a hi per 14x 2.5" drop base air cleaner assembly.
the best one is this one from the 60's and 70's corvette and camaro. You can still buy it from restoration sources.
You'l need a 3/8" spacer ring (edelbrock) with this aircleaner base and the edelbrock carb.
Old Mar 2, 2003 | 04:49 PM
F-BIRD'88's Avatar
The GM aircleaner base looks like this
The back needs to be trimmed a bit to clear a HEI distributor.
The 3/8" plastic spacer ring is in the edelbrock catalog.
This is how to get hood clearance with a 14x2.5" air filter
and high rise intake on a FBody.
There is even enough clearance for a nitrous plate.
Try this GM part #
6423907
HP 14" Air Cleaner
$96
Some one needs to do a sticky on this stuff.
Old Mar 3, 2003 | 05:51 PM
NutZ's Avatar
Get a Road Demon, Brocks are rebuilt Quadro JUNK made even worse. But if you want to reset back to scratch. Close the pins all the way, and then back them both out 2 and one half turns and fine tune it from there.
Old Mar 3, 2003 | 07:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Do you have ANY idea what you're talking about?
Old Mar 3, 2003 | 07:40 PM
NutZ's Avatar
Well I know what I has happened to me, LIke have owned 2 brand new 600 Brocks, and both of then didn't even last long. Did nothing but flood my 350 in my 83 monte carlo, didn't matter what i did to the carb rebuild, tune it, or reset it to factory settings, nothing. And i have owned this Road Demon for 2 years and I have only had to replace gaskets twice, and thats just standard maintance
Old Mar 4, 2003 | 12:57 AM
black84-6spdz28's Avatar
wow....i have had mine edelbrock for 3 years and never had to fix anything on it..
Old Mar 4, 2003 | 07:27 AM
NutZ's Avatar
Luck of the Draw i Guess, but i'll never buy one again
Bubbajones_ya
Jul 6, 2024 08:32 PM
sreZ28
Oct 22, 2015 08:21 AM
S10K20
Oct 7, 2015 06:45 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
toronto formula
Sep 10, 2015 07:31 AM
