the low down on the stock pump for carbs...
Old Apr 29, 2003 | 01:42 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
My 388 seems to die out when the gas is all the way down. I have the AFPR from Holley at around 7psi. Should I get another fuel pump that supports up to 700hp, or is my stock TBI pump enough? If it is enough, then why is it dying out?
Old Apr 29, 2003 | 09:41 PM
Jester's Avatar
You're kidding right? I mean....why would you ever think that a pump designed to support a whopping 170hp would feed anywhere near 700?
Old Apr 30, 2003 | 06:46 AM
Biochem's Avatar
Car: 2002 SOM z28
It's all about the volume, not the psi. No way a stock TBI pump can support enough...
Old Apr 30, 2003 | 12:55 PM
Momar's Avatar
LOL. Seriously, it seems that a lot of people get volume and psi confused. People tend to think that as long as you have enough psi of fuel that it will support the motor when it wont support that much pressure at larger volumes.
Old Apr 30, 2003 | 01:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
He didn't say he had 700HP, he was asking if he should buy an aftermarket pump that would support 700HP.
The only way to know if your pump isn't keeping up is to monitor supply pressure under the conditions that are giving you problems. You also need to consider where your filter is in relation to the filter - if upstream of the filter, you could have good pressure and not enough flow through the filter. If downstream of the filter, low pressure may not be the pump but a clogged fuel filter.
Setting the fuel pressure at idle is at best a setting for the max fuel pressure. The regulator won't keep the pressure up there if the fuel pump can't meet the demand.
I assume you're not over in Kuwait right now...
Old Apr 30, 2003 | 01:58 PM
Momar's Avatar
He may not be making 700 hp, I dont know, but I wouldnt be suprised if he was making 3 times what the tbi motor origionally was with that setup.
Old Apr 30, 2003 | 11:06 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
just spend the money on a new pump... ur not getting enough fuel!
Old Apr 30, 2003 | 11:18 PM
ronterry's Avatar
Car: '94 Corvette
Aluminum has a funny way of melting around 1250-1300°...If you run it seriously lean at high rpm ----- well do you like your cylinder head? How about your pistons? Ever heard the phrase "Ohhh he burnt a piston"?
http://www.holley.com/HiOctn/ProdLin...SFP/FMSFP.html
I personally have the Holley Mechanical 170GPH...
Ron
Old May 1, 2003 | 08:40 AM
84TAProject's Avatar
How about this, I just had my high volume pump die out on me, and my father put on a stock replacement one, and now the car feels like its starving for fuel at high rpms or if I stay at WOT for an extended length of time. Won't get real high into the revs in 2nd like it would with the other pump. Of course my father accuses the floats in the carb. Could it be the pump. Im only pushing like 280 hp in the t/a, think Ive got enough fuel flow with a stock replacement pump?
Old May 1, 2003 | 11:24 AM
five7kid's Avatar
An ounce of data is worth a pound of speculation.
Get a fuel pressure gage and find out what's going on. Fuel pressure at idle is insufficient data.
Old May 1, 2003 | 12:24 PM
GOFASTER's Avatar
Engine: 388 ci
No I am not in Iraq yet. As I type I am in my desert uniform waiting on the next plane out of the states. My unit has had some trouble getting another flight for me and about 300 other troops. I am on my way, but all this time has got me thinking about my car back home. I will be gone for about 7 months. I should leave in about 1-2 weeks if all goes well, you have to understand the military, they have been telling me 5 stories about flights and when, my family is getting tired of it and so am I. Very soon now though.
Your right, my pump is not going to hold it up. I get great PSI at idle but at WOT it dies a lot. I am going with a 700hp pump when I get home, that should work.
Thanks for the help
GOFASTER
Grant2k
Jul 10, 2018 04:01 PM
italiano67
Dec 11, 2016 09:21 AM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
NBrehm
Aug 25, 2015 11:49 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
