Post Your Carb'd Motor Pics
Old Nov 13, 2005 | 10:27 PM
  #401
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Originally posted by Dialed_In
Rip it all out and run your own wiring. That will give you the option of running it where you want. I wired up an aftermarket fuse block and mounted it to the inside the firewall on the passengers side. Everything in the engine bay or engine related (msd, fuel pump, fan etc.) is powered by that panel. That way if there's a problem I don't have to trace it through the GM harness and fight with fuseable links and daisy-chained circuits.
what about the dash stuff.. did you run all new wires for the gauges?
Old Nov 20, 2005 | 10:13 PM
  #402
vinceanity92's Avatar
Car: 1992 rs
Engine: 305 tbi
Stingraye's engine bay is best looking to me very good job man
Old Nov 27, 2005 | 02:25 AM
  #403
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
New project
Old Nov 27, 2005 | 09:10 PM
  #404
MKnight's Avatar
Before:
After:
*NOTE* Still not done here, have to remove a few left over AC hoses since I removed AC from the car. Also non of my new valve covers, intake manifold or carb are attached yet.
Old Nov 27, 2005 | 09:38 PM
  #405
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Here an update of mine. Got some new heads Now I can detail her up
Old Dec 12, 2005 | 09:28 AM
  #406
89BlueRSCamaro's Avatar
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
Re: What the *ell ----->
Originally posted by John in RI
Here's my 84 Berlinetta.
355ci, T56, 3.70 BW with PBR, ect... It goes pretty good compared to the LG4 that was original to the car !!!
DAMN!!!! Of all the engine pics i saw this one caught my eye....this has got to be the best (IMO) engine bay....sure there are others that are nice but this one for some reason looks pretty damn good.....nice job
Old Dec 12, 2005 | 12:58 PM
  #407
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Heres an update of mine.
Old Dec 13, 2005 | 09:43 AM
  #408
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Heres mine.
Old Dec 14, 2005 | 12:53 PM
  #409
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Old Dec 17, 2005 | 11:19 PM
  #410
pmpnavt's Avatar
Engine: L98 350
Transmission: 700r-4
this is my first post of my tpi -->carb conversion. ill have the rest in a few days
Old Dec 17, 2005 | 11:21 PM
  #411
pmpnavt's Avatar
Engine: L98 350
oops that was the small picture...
Old Dec 23, 2005 | 03:04 PM
  #412
pmpnavt's Avatar
Engine: L98 350
pic
my engine now with the intake on
Old Dec 23, 2005 | 07:40 PM
  #413
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Mine are all autometer, but even if you're using the stock setup all you have to do is run a single wire to the senders. Same amount of wiring either way.
Old Dec 30, 2005 | 08:34 PM
  #414
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Side view
  #415
JDF-Z28's Avatar
Car: 1983 Z28
Front view
Old Jan 2, 2006 | 09:37 PM
  #416
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Originally posted by jbenge
Heres mine.
That is a sweet engine bay, where did you get that ac/heater cover?
Old Jan 2, 2006 | 10:14 PM
  #417
Dialed_In's Avatar
He made it.
Old Jan 3, 2006 | 06:04 AM
  #418
jbenge's Avatar
Necro,
Dialed_In is right, it was custom made by a friend of mine. Its a piece of aluminum bead rolled and polished.
Old Jan 15, 2006 | 06:55 PM
  #419
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
for some reason guys i cnat post pics says there to big of a file. anyway just check out my link in my sig.
Old Jan 27, 2006 | 03:14 AM
  #420
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Sweet ride BlueBeast, I've always liked the looks of cowl induction.
Old Jan 27, 2006 | 11:41 AM
  #421
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
My new 350HO/330HP
Old Jan 28, 2006 | 10:12 AM
  #422
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the new 360! 113 casting aluminum l98 heads, a worked over 750 double pumper, xe274h, 10.2:1 c/r, on pump gas and driven EVERYDAY BABY!!!
Old Feb 2, 2006 | 10:26 PM
  #423
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
here is mine Trick Flow heads, team-g intake, 650 holley DP, Comp cam, eagle rods, steel crank, KB pistons, 355
Old Feb 4, 2006 | 07:19 PM
  #424
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
heres mine
and a link to my homepage
http://hometown.aol.com/badass355ciz...age/index.html
Old Feb 4, 2006 | 07:25 PM
  #425
and another
heres 1 more
Old Feb 9, 2006 | 12:41 AM
  #426
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Heres a couple of mine.
Don't mind the tie wraps...lol
those were temporary.
Old Feb 9, 2006 | 04:08 PM
  #427
battz86's Avatar
Heres a few shots..
Old Feb 24, 2006 | 04:34 PM
  #428
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Updated pic
Old Feb 26, 2006 | 09:53 AM
  #429
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
here is mine
Old Apr 1, 2006 | 11:01 PM
  #430
87IrocTim's Avatar
Car: 87 Camaro IROC Z-28
Engine: 1976 chevy 350 far from stock
Transmission: stock tranny
My current project, this is an older picture, now has a holley x-celerator single plane manifold and holley 700cfm carb.
Old Apr 2, 2006 | 01:38 AM
  #431
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
LG4- before:
During:
5.7 Liter H.O.- after:
Leon.
Old Apr 2, 2006 | 05:17 AM
  #432
EvilCartman's Avatar
Car: '82 Z28
Another update, here's mine from about 20 min ago. Still need to do a few more things to it.
Old Apr 2, 2006 | 02:05 PM
  #433
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
here's my carb'd motor...350HO crate w/ vortec heads, 212/222 duration @430/460 lift, vortec RPM intake, Edelbrock 1405( crazy tuned), K&N filter, K&N stubstack, MSD Superconductor Wires, Proform Distributor Kit, 160* T-stat, painted Hooker 2055's, 3" catback w/ 80 series, Spohn Wonderbar and SFCs...couple other things...
Old Apr 3, 2006 | 01:49 PM
  #434
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
just and old barn motor here!
I hope this upload works
Old Apr 3, 2006 | 02:04 PM
  #435
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
So exactly how do you install connecting rods backwards? There is no front and back to them
Not true. There is a tab on each rod cap cast in to give you something to whack on to remove the cap without damaging the critical mating surfaces. With the rods installed correctly, these tabs face away from each other (face the thrust surfaces of the crank). Any stock rods I have seen have a larger thrust face on the crank side than the partner rod side as well.
Old Apr 7, 2006 | 11:58 PM
  #436
bb92RS350's Avatar
Car: 1992 Cheverolet Camaro RS Heritage
Engine: Vortec Headed Carbed 350
Axle/Gears: 9-bolt with 3.27's
those look great here is mine in a couple of stages sorry for all the pics
Attached Thumbnails Post Your Carb'd Motor Pics-dual-snorkle-1.jpg   Post Your Carb'd Motor Pics-edelbrock.jpg   Post Your Carb'd Motor Pics-engine-001.jpg
Old Apr 8, 2006 | 10:44 PM
  #437
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Nobody said I had to post pics of a thirdgen
This was taken a while ago... it's gonna be nice out tomorrow, probably gonna polish some stuff up.
My '84 from back in the day... couldn't find a pic of the motor (LG4 w/ Performer Intake and 1406 Carb).
Old Apr 8, 2006 | 11:17 PM
  #438
TRSCobra's Avatar
Car: 2018 Corvette Grand Sport Z07
Transmission: C7 Z06 TR6070
Yes, I know its ghetto. But im lazy. Someday I'll get around to cleaning up this car's engine compartment, re-reouting wires, etc. But for now, I just drive it.
All that and a 14.93 @91.5
Old Apr 8, 2006 | 11:24 PM
  #439
SScott's Avatar
Car: 91 Mustang
Engine: 306
Axle/Gears: 8.8 4.10's
TRSCobra - Those are the biggest plug wires I have ever seen! What are they like 8...teen milimeter? They look like garden hoses. I like em!
Old Apr 8, 2006 | 11:32 PM
  #440
TRSCobra's Avatar
They're accel 8.8mm wires with the pro-sleeve. The sleeves go from about 4" from the cap down to the plug boots. But they still burn through Im on my second set. They'd be routed better if i had some kind of retainers for them.
Old Apr 8, 2006 | 11:50 PM
  #441
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Heres my 408!!
Attached Thumbnails Post Your Carb'd Motor Pics-mvc-045s.jpg   Post Your Carb'd Motor Pics-mvc-044s.jpg
Old Apr 9, 2006 | 12:07 AM
  #442
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I'm jealous of all these brake boosters
Y'all make me want to clean up my engine compartment.
Old Apr 9, 2006 | 06:48 PM
  #443
87IrocTim's Avatar
New motor picture
This is a picture after i just installed my Weiand X-CELerator Manifold. Will soon have a 700cfm Holley double pumper, and yes, a 1 inch tall K&N filter.
Old Apr 10, 2006 | 07:28 AM
  #444
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
What kind of carb hat is that?
Old Apr 10, 2006 | 01:55 PM
  #445
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
<a href="http://photobucket.com" target="_blank"><img src="http://i11.photobucket.com/albums/a156/nickdomp/engine1.jpg" border="0" alt="Image hosting by Photobucket"></a>
Old Apr 10, 2006 | 03:45 PM
  #446
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
Don't see too many of these... (installing new Polished 750cfm supercharger Holly this month, after i bore and stroke out the engine)
ohh btw, if somone can PM me a link to a replacement air-filter that fits that, i'd be gratefull... lol.
Old Apr 10, 2006 | 07:17 PM
  #447
Car: '82 Z28
Which model is that? I've been looking into buying a Weiand 177 to stuff under my hood. Almost bought it last month but spent too much redoing my fuel system, oops.
Old Apr 10, 2006 | 09:53 PM
  #448
bb92RS350's Avatar
The carb had is from a dodge dakota 5.9 but a 5.2 would work too i am not using it now cause i blew a gianto hole through the thing when my car backfired luckly no plastic made it through the carb. Im looking for another but havn't had the chance to actually look if you know what i mean
Old Apr 10, 2006 | 10:14 PM
  #449
Nightcruzer's Avatar
Car: Trans Am
Here's my 83 TA
Old Apr 10, 2006 | 10:53 PM
  #450
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
heres my beast.....
