Post Your Carb'd Motor Pics
Car: 1991 Pontiac Firebird Base
Engine: 350 Carb'd and Cammed :)
Transmission: Stock T-5
Axle/Gears: Stock
Re: Post Your Carb'd Motor Pics
Here is a pic of mine. 350 with a comp cam kit. Hydraulic flat tappet 262/270 lift cam, 1.5 roller rockers, 2.02 valves, wieand intake with quadrajunk (Holley replacement soon). Please comment, Thanks
Car: 1984 15th Anniversary Trans Am
Engine: 5.7 Goodwrench (for now)
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
i still have to hook up the nitrous, gas lines, and the vacuum stuff but its almost done.
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
just my little 358 all ready to go just need to finish hooking up the nitrous and some small stuff and she is good to go
Fuel system is a Barry Grant Mighty demon, intake Edlelbrock air gap, Mallory 4309 fuel regulator , Holley 255ltr in tank fuel pump (soon 250 wet shot NOS plate )
also my old 377 may it rest in pieces
Car: 89 RS,02 WS6 M6,08 GMC Sierra SLE
Engine: ZZ4HCI, LS1, LY5
Transmission: T5/T56/4L60E
Axle/Gears: 323,342,373
Its a little messy and an old picture but you get the idea. Go Carbs!
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hey buddy, that 408 is lookin' great! what is the alternator bracket?
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Engine: 7.0L
where did you run the crossover vent to? i've run mine to the radiator side of the thermostat housing in the passed with good results, but am about to go to an electric water pump and need to put it somewere else. i need to go look at your build thread again, lol.
wowzers that thing is pricey! 200! do you have any more upclose pics? maybe in your build thread? i'll look there. i'm going to see if i can build one for my little bro's and my buddy's cars.
The Speed Inc. bracket is a quality piece but there may be a better alternative now. The pulley on the alternator did not line up correcty on mine and I had to grind quite a bit off the back of the alternator to clear the head. I had to shim the bracket out about .085in and use a 5 rib belt, the front groove on alternator pulley stuck out too far to use. And if you shorten the spacer you have more of an interference issue with the alternator and the back of the head. Now that I've got it figured out its no big deal but it was a pain, it would be nice if a high dollar part would just bolt on and work.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Still the same 355 with things around it changed from whenever I posted my old pics...
Car: 84 trans am
Engine: 350 bored .020 over
Transmission: TH350 w/ stage 2 B&M shift kit
Axle/Gears: 9 bolt/3.27
New 350 bored .020 over, speed pro mild cam, new pistons, holley street dominator intake, and 650 cfm edelbrock carb.
Car: 85 Z28
Engine: 327
Those of you who went from a tpi car to carb with mech fuel pump. How are you runing your fuel line from drivers side to pass side, and pic if you could.
Car: 86 camaro sport coupe
Engine: 350 ci. alluminum headed sbc
Transmission: TH350 w/9" 3800 conv.
Axle/Gears: 31 spline strange /4.11
My car was a 6 cyl. The fuel line ran down the driver side. I have a holley elec. pump and ran alluminum line down the passenger side.
Car: 1986 Camaro Z28
Engine: SBC 400
Transmission: 700 R4
Heres mine, Its a 400, still pretty much all stock.
Its not done yet but am trying to keep it as clean as possible.
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
I seen you asking about fuel pumps. Just a note of advice. Without a vapor
return line you will most likely get vapor lock during the summer heat. I learned
this the hard way when trying to use a Holley performance pump which did not
have a provision for vapor return. It seems none of the standard performance
pumps have vapor return option. I finally found one that did and haven't had a
vapor issue or fuel starvation issue.
http://www.robbmcperformance.com/products/chevy550.html
P.S. ooh and by the way, i ran a braided fuel line and the vapor return line
through the frame and exits right near the fuel pump.
Car: 85 Z28
Engine: 327
I believe mine has a provision for a return because right now there is a six inch piece of hose with a bolt in it. And a couple of days ago someone posted what all three line in engine bay were for. So now I just need to find that thread and hook up a line.
Engine: SBC 400
It's funny you should ask that. I am actually trying figure that out at the moment. I'm trying to figure out external fuel pump mounting and plumbing so if u guys got some ideas that whould be great
Car: 85 Z28
Engine: 327
I just saw you had a block off. I have been looking at pics here for myself. Right now the way it works is that all my fuel lines are on the drivers side and pump is on passengers side of engine bay. So as of now I have a nasty looking rubber hose going over my water pump down to fuel pump. Looks like poop. Some guys retoute their lines from pump over to passenger side then up, but for myself with cost and time that is not an option. Another option which I haven't looked at would be a eletric pump then I just have to go from line in engine bay to carb
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
here is mine new air intake setup!!
before:
AFTER:
Thank for watching!!
before:
AFTER:
Where'd you get the pipe/rubber jackets to make that upper hose? I wanna do something similar lol
mockup
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: camaro iroc-z
i buyed the rubber jackets here in the netherlands!
i think you can buy it in the usa also.
the size is 4 inch.
thanks for your comment
the size is 4 inch.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
SBC w duggan heads & front drive distributor setup.
Australian stuff
Can't find it on this continent either
Can't find it on this continent either Senior Member
Car: 85 Z28
Engine: 327
Ya . I looked. Only place I saw them was in Australian forums. I would like to get me a set up someday.
nowhere, except a site w/ Robert Psiala's boats from OZ, search for duggan headed. There's 1 more guy w. these heads and the spider manifold on ozrodders forum. There are very few of these around. As far as I know, I'm about the only one w. the header adapters. Haven't seen anyone else with them.
