Post Your Carb'd Motor Pics
Old Oct 23, 2010 | 02:08 PM
  #851
pharmboy1995's Avatar
Car: '86 IROC
Engine: 357
Transmission: 700R4 manual v/b
Axle/Gears: moser 9 inch 4.10
Re: Post Your Carb'd Motor Pics
Here's my pics from last year.
Attached Thumbnails Post Your Carb'd Motor Pics-357-b-4-9   Post Your Carb'd Motor Pics-357-c-4-9
Old Oct 23, 2010 | 03:00 PM
  #852
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Sweet. NICE AND CLEAN
Old Oct 24, 2010 | 10:16 AM
  #853
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
I've posted on this thread before, but since then I have given this engine bay a full overhaul. I hid all wires that I could.
Old Oct 24, 2010 | 11:15 AM
  #854
jchaussee's Avatar
Car: 85 Z28
Engine: 327
That is nice. How did you hide all the wires? Where are they?
Old Oct 24, 2010 | 05:30 PM
  #855
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Thanks!
I moved the engine harness behind the driver side fender.
The harness to the engine now comes into the engine bay behind the engine in the tunnel.
Old Oct 24, 2010 | 05:44 PM
  #856
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Did you have to do anything to the wires??
Old Oct 24, 2010 | 05:45 PM
  #857
jchaussee's Avatar
Car: 85 Z28
Engine: 327
As far as lengthes
Old Oct 24, 2010 | 05:57 PM
  #858
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
I had to lengthen almost all of them. It was a real chore.
Old Oct 24, 2010 | 06:03 PM
  #859
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Sweet. I make look into it. I will have my dash and interior ripped out, to delete a lot of wires. Might be time to try. Looks REALLY, REALLY good.
Old Oct 29, 2010 | 07:24 AM
  #860
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
Nice work, very clean. Where did you get the overflow tank, or is it custom-made?
Old Oct 30, 2010 | 03:06 AM
  #861
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Thanks. The overflow tank is from Canton Racing Products.
Old Oct 30, 2010 | 03:51 PM
  #862
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Here is another pic! forget the 10" chrome aircleaner! its there only till I make an aluminium fabricated one to suit with valve covers!!
Any comments will be appreciated!
Old Oct 31, 2010 | 08:00 PM
  #863
oguin_studking's Avatar
Car: 1990 Firebird Formula
Engine: 358
Transmission: 700-r4
Im noticeing alot of passenger side mount alternators & batteries. Why is both of mine on the drivers side?
Old Oct 31, 2010 | 08:05 PM
  #864
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
they are different from year to year and depending on the engine and AC configuration. My 86 is on the passengerside, my 92 is on the driverside.
Old Oct 31, 2010 | 08:25 PM
  #865
Project-RS's Avatar
heres my engine bay
Old Nov 7, 2010 | 10:02 PM
  #866
91camaro248's Avatar
Car: 91 Camaro RS
Engine: 350 +60 Air gap Custom 750 DP
Transmission: 700r4 Stage 2 2400 stahl
Axle/Gears: Aussie 9 3.27 Posi
my 360ci
Old Nov 8, 2010 | 03:52 PM
  #867
gtanut's Avatar
here is apic of mine 87 gta mild bbc with a little nitrous
Old Nov 12, 2010 | 04:47 AM
  #868
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Not an Fbody (one day Ill have another), some of my A body just got running. Fabbed air cleaner will be made when I have time and wires completely hidden. 40 miles on it so far, addicted to solid rollers lol.
Old Nov 12, 2010 | 09:37 AM
  #869
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Man, look at all that space under the hood??
Auggie
Old Nov 12, 2010 | 09:45 AM
  #870
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
heres mine. i got rid of this car last summer but i have another one i'm working on. green one in my sig. i have a hillborn carb scoop for that one and 750 holey carb. post that pics when i'm finished.
Attached Thumbnails Post Your Carb'd Motor Pics-001.jpg   Post Your Carb'd Motor Pics-002.jpg
Old Nov 12, 2010 | 07:37 PM
  #871
OSU-MET's Avatar
Car: 1984 Camaro Z28
Engine: 305 H.O.
Axle/Gears: .373
Here's mine that my dad and I bought about 5 months ago. We've put a lot of hours into the car replacing the things that need to be replaced on a 26 year old car. Things like fuel, vacuum, break and radiator lines/hoses and a lot of other parts. This car was my first engine to completely pull and install so I can proudly post some engine pics. We've tried to maintain the originality of the car as you can see in the pics. Well, we did remove the smog equipment but other than that, it's 100% original. I do have to say that these are pretty neat cars.
Old Nov 12, 2010 | 07:39 PM
  #872
OSU-MET's Avatar
Engine: 305 H.O.
Axle/Gears: .373
Very clean, Manovox!
Old Nov 13, 2010 | 01:18 AM
  #873
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
tnx my friend
Old Nov 13, 2010 | 09:40 AM
  #874
Auggie's Avatar
OSU-MET, you had better keep a close watch on the upper rad hose because when the engine gets hot or you reach high RPM the upper hose will come in contact with the A/C v-belt.
Auggie
Old Nov 13, 2010 | 09:53 AM
  #875
Auggie's Avatar
Forgot pic.
Auggie
Old Nov 13, 2010 | 12:07 PM
  #876
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Mine:
[IMG][/IMG]
Old Nov 13, 2010 | 07:24 PM
  #877
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
Old Nov 14, 2010 | 11:16 PM
  #878
OSU-MET's Avatar
Engine: 305 H.O.
Axle/Gears: .373
Auggie, I appreciate the heads up! It's a coincidence that you bring this up because I recently had to replace the upper hose for this very reason. I was wiping things down under the hood and noticed that the upper hose was rubbing on the v-belt once it warmed up and began to sag. Thankfully, I caught it in time before it cut completely through the hose. I went ahead and bought the better quality upper radiator hose that is much more resistant to sagging and has a better shape so that it stays away from the belt.
OSU-MET
Old Nov 15, 2010 | 12:31 AM
  #879
Engine: 358
Originally Posted by Iroc-Dennis
I Love That InTake!!!!! Expensive but the baddest intake out there in my opinion...sooo jealous! Clean car BTW!
Old Nov 15, 2010 | 07:14 AM
  #880
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Attached Thumbnails Post Your Carb'd Motor Pics-20101114112019.jpg   Post Your Carb'd Motor Pics-20101114112026.jpg   Post Your Carb'd Motor Pics-20101114112042.jpg
Old Nov 23, 2010 | 10:00 PM
  #881
gregxx's Avatar
Car: 84 Z-28
Engine: 355 750 double pumper
Transmission: TCI Turbo 350
Axle/Gears: 4.10 spool
84 z28 camaro 350 bored .30=355 4bolt main dart2 2.02 aluminum heads lunita voodoo540 lift cam lunita pushrods and roller rockers jesel timing gears edelbrock endurishine hi-rise intake proform 750 race carb kieth black pistons and rods moroso hi volume oil pump holley elec. fuel pump msd 6al ignition box msd distributor and wires hooker super comp ceramic coated shorty headers into 3"pipes to cherry bomb mufflers msd mini torque starter cool-it radiator w/elec.fan summit chrome catch can,water pump,alt,powersteering pump all aluminum pulleys optima red battery 4" cowl hood 10 bolt chevy rear with eaton spool 4.10 gears and moser axles weld draglite wheels ed quay custom built aluminum engine panels tci th350 trans with 3500 stall converter b&m shifter all autometer gauges
Old Nov 23, 2010 | 10:32 PM
  #882
gregxx's Avatar
Car: 84 Z-28
I dont know how to make the pics bigger.
Old Dec 3, 2010 | 12:57 PM
  #883
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
What kind of master cylinder is that, it's so small. You have the cleanest car on here so far, nice work!
Old Dec 3, 2010 | 01:00 PM
  #884
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
WilyK9.....What kind of master cylinder is that, it's so small. You have the cleanest car on here so far, nice work
Old Dec 5, 2010 | 03:29 PM
  #885
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
Finally got a crate motor for my formula. a guy sold me his chevelle for 5k and it had a brand new 425hp 410tq crate from proformanceunlimited.com so
I sold the chevelle and kept the crate only had to come 2500 out of pocket. here's my pic
Attached Thumbnails Post Your Carb'd Motor Pics-imag0164.jpg   Post Your Carb'd Motor Pics-imag0131-1.jpg
Old Dec 6, 2010 | 06:35 PM
  #886
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
This is my setup, not finished I just wanted to show five7kid the hat.
Old Dec 11, 2010 | 12:12 AM
  #887
dirtrides2009's Avatar
Car: 1985 Firebird
Engine: LG4 305
Looks like you might need a new windshield... Ouch!
I like your intake setup though... lookin good
Old Dec 13, 2010 | 07:56 PM
  #888
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
LOL yes a new windshield is needed, but that was the main reason I was able to get this car. It was a lovers quarrel and she took it out on the car. When he found out what she did, she went to the hospital, he went to jail.
Old Jan 5, 2011 | 04:32 PM
  #889
frankandcat's Avatar
I have a 350 chev engine bored 60 over,300 double hump heads with 2.02 and 1.60 valves,roller rockers ,501 lift cam,edlebrock torker intake,10:1 comp.What is the best carb.First time user,hope I'm doing this right.
Old Jan 15, 2011 | 04:38 PM
  #890
91_rs-teal's Avatar
Car: 1991 Camaro, Best 12.40 @ 115.8 MPH
Engine: LS1, HCI, Headers
Transmission: T56, Monster Stg. 4
Axle/Gears: 7.5" 10 Bolt - 3.73's w/ posi
heres mine alternator original from a 92 prob has 200k on it, edelbrock headers havent been coated in prob 8 years... still looks kewl
Old Feb 3, 2011 | 07:21 PM
  #891
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
383 with TFS heads, Edelbrock intake and carb.
Old Feb 3, 2011 | 09:00 PM
  #892
vangogh4560's Avatar
Car: 1987 camaro lt
Engine: soon 383
like the black and gold just keep a eye on that air filter it likes to burst into flames
Old Feb 4, 2011 | 10:25 AM
  #893
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
the choke on my carb is all black from one backfire! the air filter melted to it and now there is a big hole in the air filter. i had it on my 99 ram then took it off because i didnt like the way it sounded. so i figured i would us it on my car for a quick test drive.... BAD IDEA!!!
Old Feb 19, 2011 | 04:49 PM
  #894
face215's Avatar
Car: 89' GTA
Engine: L98 with tpi to carb swap
Axle/Gears: stock
my pic of my swap, not a real good pic.
Old Mar 8, 2011 | 10:10 AM
  #895
albertrios's Avatar
Ok so it's not much, but I dont have any money, I started when I was 17, and now Im a broke joke college student at Purdue so my car is back home
Attached Thumbnails Post Your Carb'd Motor Pics-10845_106392742707519_100000103811422_148711_8247028_n.jpg   Post Your Carb'd Motor Pics-0723091455.jpg
Old Mar 8, 2011 | 10:12 AM
  #896
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
How is the rest of the car?
Old Mar 8, 2011 | 01:04 PM
  #897
mackjar66's Avatar
Car: 1989 GTA
funny I only live 10 from Purdue back home. How are you enjoying that Indiana weather
Old Mar 11, 2011 | 08:53 AM
  #898
albertrios's Avatar
It's completely random, but I'm used to it. I'm from northern Indiana
Old Mar 11, 2011 | 08:49 PM
  #899
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
most up to date picture i have:
Old Mar 11, 2011 | 08:50 PM
  #900
Twin_Turbo's Avatar
Smokey Yunick fan??
