Post Your Carb'd Motor Pics
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
Re: Post Your Carb'd Motor Pics
thanks go with ls their ausome motor to start withlike abig block sky is the limit terry
Car: '85 Z28
The good old LG4 on its way out:
The 355 waiting to replace it... hoping to have it in this weekend!
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Car: 86 IRoc
Engine: 383 @ 505hp 530ft/lb torque
Transmission: TH350
Axle/Gears: 10 Bolt and 2.73
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Car: 86 IRoc
Transmission: TH350
Car: '85 Z28
82-87 GM F-Bodies ( Camaro, Firebird )
14x3@110 air box, AF3 air filter, 14AL/Fbase,
14AL/CCover, 2x G28108 Tubes, 917 Intake, 918 Intake, Stud & Nut
Sold as Kit part # F14x3@110 stg II H.O.
Car: 1985 IrocZ
Engine: 305 bored 40 over
Just got this for 1500 bucks on a lean sale. lucked out and met the guy who built the motor so I got the whole story, anyways lots of work ahead for me.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Engine: 7.0L
lol, my carb mounting flange is above the hoodline...
Car: 91 Camaro RS
it looks like you run a really tall intake. if you stick with a normal height intake you can squeeze a 3" filter under the stock hood. my pic is an rpm airgap with a holley street avenger carb on top
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Car: 91 Camaro RS
well the LS is still a small block, just a gen IV small block. but yea, its a whole diff story with an carbed LS swap.
Car: 84 pontiac firebird
Engine: 355
Transmission: TH-350
Axle/Gears: 9 inch with 4.30s
This is what my 1984 Firebird engine looks like. Its a 355 with 9.0 to 1 compression. Callies lightweight crank, crower rods, je short skirt pistons, dart 200 heads, .520 solid lifter cam, edelbrock victor jr. intake, QFT 750 carb with E85 conversion kit, msd distributor, edelbrock nitrous with 100hp shot. This engine goes 11.32 @ 121 mph on E85 and 11.61 @ 117mph on 93 octane, The car went 10.70 @ 125 Mph with 100hp nitrous. I didnt have time to shoot the nitrous with the E85 setup. Heres my 10.70 nitrous pass http://www.youtube.com/watch?v=O70ewShLG2A
Car: 1986 IROC-Z
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
Here is my new project. Its a 350 with Dart heads,Team G intake, Pro Systems custom 780 carb, Mallory Unilite distributor, Comp Cams custom gind cam, Harland Sharp 1.6 roller rockers, BBK underdrive pulleys.
Car: 84 Camaro Z/28
Engine: 5.7 .030 over 10.5:1CR
Transmission: BW T-5 from 87 Firebird
Axle/Gears: 3.73 LSD
My new 10:1 355 just before it went in my 84Z. And my brothers early Xmas present to me, he smoothed and painted and stenciled my factory manifolds!
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
If I see you around, hopefully you'll let me hear that run. Looks mean.
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Just had a few extra hours and pulled all of this out. (computer is now garage art)
Yeah now more clutter! Easy spark plug changes!
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Here is mine, 388 sbc Brodix aluminum headed w/ 3" true dual exhaust.
Hey Grod98, do you plan on racing this at the track and what rpm range is this setup going to run in? My RPM range for my setup is 3500-7000, and I shift anywhere from 6800-7000 rpms. Yours I'd imagine with the tunnel ram would be what around 4000-8000 rpms, but not with a none roller valve train setup as I see that the motor still has the stamped steel rockers and not roller rockers? Although I have not seen too many 383 sbc running that high in the rpm range as I thought they were designed for huge torque at a lower rpm range. I've seen lots of 327(331) and 350(355) make full use of a tunnel ram running anywhere up to 8000-9000 rpm and still be able to drive on the street.
Engine: 7.0L
i shouldnt have issues with mine. i am placing an order today for the correct cam (recommended by comp cams for the tunnel ram), matching valvetrain, pistons, and odds and ends to finish the motor. mine wont see much track time and i dont plan on revving past 6k on the street since mine is a weekend car
Car: 88 trans am
Engine: 350sb
Transmission: t400
Axle/Gears: 7.5/2.73
