high rpm problems. HELP?
Old Jun 17, 2003 | 03:35 PM
T/A_SXracer's Avatar
Car: '85 T/A
Engine: 385 full roller
For some reason when im getting on my car, especially if i shift it by hand (i have an automatic), once i hit about 4500-5000 rpm the engine starts bogging down really bad, the only way i seem to be able to avoid it is if i roll the throttle on really smooth, i cant just stomp on it. it tends to be really embarassing to, especially when your racing someone, and all the sudden they just jump ahead.
Please help. Thanx in advance.
Old Jun 17, 2003 | 04:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What engine?
What carb?
What modifications?
Old Jun 17, 2003 | 04:05 PM
Car: '85 T/A
Wow, sorry about that, its a 355 with edelbrock performer intake and carb. it has regular manifolds to a 3.5 y pipe, no cat. and another thing is, that it doesnt always do it.
Old Jun 18, 2003 | 07:56 AM
five7kid's Avatar
Sounds like hot fuel, since you say it doesn't happen all the time. Or, it could be weak fuel delivery, the best way to determine that would be to get a fuel pressure gage installed and see if it drops down under those conditions.
What kind of fuel pump/pressure regulation are you using?
Old Jun 18, 2003 | 10:53 AM
Car: '85 T/A
it's just the cam driven pump on the engine, and there is no pressure regulature. but about the low fuel pressure, the car was originally a TPI car, and i believe that who ever converted it left the original fuel pump in the tank as well, although it isn't working because they hacked all of the wiring, could it cause low fuel pressure if the manual pump i have now has to draw through the old electric pump. Thanx in advance.
Old Jun 18, 2003 | 12:10 PM
five7kid's Avatar
Like sucking a Big Gulp through a coffee stirrer...
Old Jun 19, 2003 | 06:27 PM
ILikeFtLbs's Avatar
Car: Whatever I can get to start.
Engine: broke 305 H.O. (now a N.O.)
Could it be a broken secondary spring in the carb? That'll cause exactly what you're describing.
Old Jun 23, 2003 | 11:35 PM
CamaroX84's Avatar
If it does end up being the broken spring.....ditch your carb if you can afford it and get a carb with mechanical secondaries.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
