edelbrock manifold question
Car: 82 T/A
Transmission: th350 w/ high stall C.
what is the best edelbrock manifold for best low rpm torque but also decent breathing at 5000.
performer eps , performer air gap, or a performer rpm air gap?
Car: 82 T/A
ok will this help get some answers; it is a 350 with 1000-5500 rpm cam and edelbrock performer 750 cfm carb.
I think the eps is worse than the performer air. But I guess for my lower rpm target range the performer air gap should be good, rpm air gap prolly has higher power range.
Am i on the right track or am i wrong
thx in advanced
thx in advanced
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
I'ed go with the RPM airgap.The performer is best left for a 305.
Plus the RPM airgap will get even better down the road as you add mods.
Car: 82 T/A
ok but even though the rpm airgap is rated at 1500-6500 rpm, will it give me atleast some strong low rpm power enough to smoke the tires from dead stop?
Transmission: 4L80E/4L80E
You've got to keep the parts matched. A cam with 1000-5500 RPM powerband and an intake with a 1500-6500 RPM powerband is a mismatch. You'll end up with the worst of both.
Build your engine around the cam. A Performer (although I prefer the Action+ or GMPP) is fine for this application.
Oh, raising the powerband RPMs will reduce the ability to "smoke the tires from dead stop", especially if the "package" doesn't include matching torque converter & gears. Why you'd want to do that (or, to put it a better way, why you don't want to do that) is a topic for another thread.
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
PERF RPM AIR-GAP
in a magasine i saw a 550HP engine (383) with performer rpm air gap, then they but a small carb blower, it made 750HP. was a carbed engine, and blower is the one you but your carb in a small air sealed box, neat.
also the performer rpm air gap look great... i realy like the gap.
Car: 82 T/A
ok thats it , for my bored out 350 im going with the performer air gap(idle-5500rpm) and the Comp Cams Xtreme Energy cam (idle-5200rpm) and the edelbrock performer series 750cfm w/ electric choke. That should solve all the fuss
86IROC112
Aug 17, 2015 02:00 PM
