EFI fuel pump to CARB how??? very confused
Old Sep 8, 2003 | 05:40 PM
stone89ROC's Avatar
Car: for now my Jeep while im building my Camaro
Engine: building a 350 with about 440HP and 450lb
Transmission: W.C. T-5 dont know how it will hold up..
ok well i do know alot about enignes but me and my friend are builing our first and i need to know how to get the fuel to my carb hence im going from 305 TPI engine to a 357 CARBed. ne ways i know the EFI fuel pump sends too much pressure for the carb and i know there are regulators out there. but how is the whole thing setup can someone please tell me how to get the fuel to my carb without going into my fuel tank?
Old Sep 8, 2003 | 05:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Look at this post from last week. https://www.thirdgen.org/techbb2/sho...hreadid=199078
Let us know if you have any other questions. Only difference is your pump will put out up to 50 psi, whereas TBI is on the order of 9-10 psi. The issues and resolution are identical, however.
Old Sep 8, 2003 | 06:19 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
I unplugged the connector from the fuel pump relay on the firewall, bolted a used mechanical fuel pump to the block, redid the pipes and that was it. I haven't used a return line. Just blocked it off.
The mechanical pump pulls through the electric one. Dead cheap and quick. Works well.
Andy.
Old Sep 10, 2003 | 06:10 PM
nathan2003's Avatar
Car: Camaro
i went tbi to carb and all i needed was this little beauty.... it can handle anything you throw at it without gettin in the tank good luck man.... http://www.martelbros.com/cgi-bin/st...ry/mallory.htm go down the page its the 3 port fuel pressure regulator... it will handle all your fuel pressure problems good luck
Old Sep 11, 2003 | 07:16 AM
Car: 91 camaro rs
I couldn't get to that link. Is it this one?
Andy.
Old Sep 11, 2003 | 02:14 PM
dennis6's Avatar
Car: 1991 Camaro RS
You need a mallory #4309 regulator. I have one and a whole carb setup 4 sale in the classifieds.
Summit and Jegs also carry them.
Old Sep 14, 2003 | 10:57 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I have posted this in other threads too but i will do it here too. I hav a TBI pump and the 4309 regulator and my fuel pressure wont stay set. I have taken the regulator apart to check it and its fine. I can set it at 5psi, sometimes it will go down to 0-2, other times it will go up so high it blows the needle and seat apart, I can hear the float bouncing up and down.
Old Sep 19, 2003 | 10:56 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Im using a Barry Grant FPR on mine. I swapped from a V6 to V8.
Attached Thumbnails EFI fuel pump to CARB how??? very confused-regulator.jpg
Old Sep 21, 2003 | 09:50 PM
dennis6's Avatar
Car: 1991 Camaro RS
I haven't had a problem with a 4309. Are you sure you have it hooked up right?
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
