Post pics of your fuel filter
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Um down here somewhere.....
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Post pics of your fuel filter
Originally posted by Daz
I just squeezed a mr gasket fuel filter on it..Im trying to see the best location
Daz
Daz
what kind of setup you have?
with my 91, its just in the stock under car location.
with my 82, i had a mechanical fuel pump and on the line that ran up from the pump to the carb, i had one just to the pass side of the thermostat housing.
with carbs, unless they have the built in housing for one in the carb (Qjet), i put them over the intake (supported somehow) just before the carb.
Car: 91 Camaro Vert
yea yea yea, i saw your stupid picture of some guy with his head under the hood of a old benz or somthing.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Can't think of what the mr gasket looks like, I used to run a Spectra? galss fuel filter, actually picked up .8 after switching to a cansiter Fram unit, heard and found out the flow on the Spectra were less than adequate. Now with the new carb system went with the Summit fuel filter circled below. This winter after I redo the drivetrain gonna get the Aerospace Billet fuel filter so I won't have to worry about it not flowing enough and dropping my fuel pressure.
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
just my experience with those garbage filters for one don't use them they are cheap peices of cr@p. i had one and it majicly exploded and fell apart when i was driving down the road gas everwhere on a hot engine throw it out and get a new one.
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, I run a MR. Gasket clear glass fuel filter with the replacement elements. It has a 3/8" inlet and a 3/8" outlet. You can see most of the filter under the pass side air cleaner cold air inlet. I have a 750 cfm Q-Jet with a stock fuel pump and have not had any problems with fuel starvation. I like the clear glass concept. One less thing to trouble shoot when things go wrong.
Auggie
Auggie
Well, I ran a Mustang GT the other day for around (5) miles (i beat him) and my corrected speedo was at 142 mph. Had to let go because a bridge was coming up fast. So, I guess all i can say is that "The proof is in the pudding"
Auggie
Auggie
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Thats nutz! Supreme Member
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Auggie,
Did you add that dual snorkle or did the car come with it? Where do you get those?
Cadillac, the car did come with a duel snorkel A/C (L69) but when I installed the 355 and modified my Q-Jet to flow 750 cfm I just felt it wasn't big enough. A friend of mine made the housing out of alum. and I bought a drop base open element A/C and put them together. It now has a 14" x 3" K&N element. There's a compeny in Canada that sell's almost the same setup but they are made out of fiberglass. http://www.ramairbox.com
Auggie
Auggie
Car: 05' GTO
Engine: 6.0L
Transmission: A4
heres mine ive had it there for the past 2 1/2 years and havnt had one single problem ever. dont know how others have bad luck with these but i havent had anything happen yet. but from what IHI said i think ill be changin mine to some thing better flowing
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i dont really know for sure, ive looked at alot of differnt companys and still yet to find out what mine is. the hood was put on ruffly 12 yrs ago im sure of.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
umm i just stuck it on. lol like the owner before me put on the edelbrock air cleaner assembly and had just a regualr 14x3 paper filter i changed it to a 14x4 K&N and i still have abou 2 1/2 to 3'' cleaence .
Man, those engine bays sure do look neat with all that emissions stuff gone. You might want to rethink that fuel line routing though.
Auggie
Auggie
Car: 2002 Formula Firebird
Transmission: 4l60e
Don't what what else to do with the fuel line. Unless I made it go around the back of the carb. That is metal line...it isn't going anywhere.
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
As for those glass see thru fuel filters, never again! mine over time came loose and blew gas over my headers, turned out the threads (aluminum)let loose , let me set along the road at 5 in the morning . Hose was to short to bypass the filter to get it home. Had to walk to the parts store 2 miles then wait for them to open and walk back
You know you guys I must be missing something here?? The fuel and return lines on my car come up the pass. side. Why do yours come up the drivers side? Fuel inj., V6 or what
Auggie
Auggie
All the fuel injected cars came up the drivers side. At least all of the ones that I have worked on. On my 87 the were, so I took the entire line down, rerouted it at the tank and moved it to the passenger side for my mechanical pump. Seemed to me to be the cleanest way when I did the V6 > V8 swap.
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
