Cleaning Carbs
Old Feb 20, 2004 | 03:30 PM
Hollowmangt69's Avatar
Car: 1984 TransAm
Engine: Remanufactured V8 350
Transmission: Automatic
Cleaning Carbs
Whats is the best way to clean a carb covered in oil? would gasoline work?
Old Feb 20, 2004 | 03:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Tear it down and soak it in carb cleaner. Otherwise you'll just end up flushing dirt into all the little passages, and then you'll have worse problems than before.
Old Feb 20, 2004 | 03:43 PM
Car: 1984 TransAm
ya ok but wouldnt gasoline eat away everything?
Old Feb 20, 2004 | 03:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Tear it down and soak it in carb cleaner" means you take it apart and remove anything that would be desolved by the cleaner.
Cleaning with gasoline is a very, very bad idea.
Old Feb 20, 2004 | 03:55 PM
Car: 1984 TransAm
why would gasoline be a bad thing? it would eat away all the dirt and crap inside. Since the carb is made of metal then it would resist the gasoline effects. besides smelling like gas.
Old Feb 20, 2004 | 04:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Gasoline is a fuel, not a solvent. If you want to use it that bad why bother asking?
Old Feb 21, 2004 | 07:40 PM
1986ROC's Avatar
Car: 1994 Pontiac Trans Am
Transmission: auto, but i want a T56
If you use gas to clean a carb, you risk starting it on fire. Gasoline has a low flashpoint, and should never be used to clean engine parts. Carb cleaner is the way to go, it removes dirt and oil very well. I rebuilt my carb 4 days ago, and carb cleaner made it look a lot better than before.
Old Feb 22, 2004 | 01:29 PM
Car: 1984 TransAm
I would like to thank 1986ROC for his review and would like to bring to Apeiron attention that this is the way you help out fellow thirdgen's.
Old Feb 23, 2004 | 12:21 PM
five7kid's Avatar
Since it's a little hard to read body language on the net, we're left with nothing but written language. From what you wrote, one would reasonably conclude that you wanted to use gasoline, and any suggestion to the contrary would be met with resistance.
Now that we got that out of the way...
You can get a can of spray carb cleaner and squirt it down from the outside. That may help the external choke mechanism, if it's gummed up from dirt & grime, but you risk what RB said in his first response.
The carb isn't all metal, it has rubber seals & paper gaskets amoung other things that can be weakened by carb cleaner. But, the spray kind typically isn't as harsh, and isn't kept on that long. That also means it isn't as effective.
What may appear to be oil on the outside of the carb could actually be varnish residue from the gasoline. If that's the case, gasoline won't desolve it. Carb cleaners will, however.
Again, the best way to clean a carb is to take it apart and soak it in real carb cleaner, not the spray kind. When you do this, it's best to have a carb rebuild kit to replace the things that are bound to be damaged in the process, and the really good news is the kit has step-by-step instructions in how to take it apart and put it back together.
Old Feb 23, 2004 | 12:51 PM
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
the man only wanted you to explain why it was a bad idea, rather than just saying "it's a bad idea". that's how learning works .
Old Feb 23, 2004 | 02:51 PM
Car: 1984 TransAm
I was talking about Apeiron, not five7kid. Although I can see how I was a little over drastic so I would like to appoligize to Apeiron.
Old Feb 23, 2004 | 04:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I would also like to apologize. There has been a spate of people recently asking for help and arguing with the responses lately, but it was wrong of me to assume you were doing the same.
Old Feb 24, 2004 | 12:28 AM
five7kid's Avatar
Good, so we can all just get along...
And my apologies for my own terseness.
Old Feb 24, 2004 | 11:06 AM
Car: 1984 TransAm
Cool, glad we are all friends once again. hahaha. Well thanks for the input guys, I just put the carb back together and it looks great. Thanks again guys.
Infested
May 22, 2018 11:56 PM
MantyZ28
23
Sep 29, 2015 11:33 AM
mdtoren
Aug 23, 2015 12:52 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
